Overclockaholics Forums » Hardware Section » Motherboards » Intel » A Thread dedicated to issues with my PC
Old 11-01-2009
Chicken Patty's Avatar
Default A Thread dedicated to issues with my PC
Sad but much needed. I am making a thread because I need advise from you guys.
Here is a list of issues I've had with my i7 rig lately.
1- Video card. Screen would go black and fan would spin up forcing me to reboot.
2- Once I replaced video card with an X300 I have, it stops issue #1 above, but now I have lost LAN and Audio, forcing me to restart to get it back only to loose it again.
3-with the x300 installed, I have now removed my sound card ( in the specs to the left) and all related creative apps/software/drivers. Seems like this is the longest i've had LAN. Of course no audio now, but the LAN connection is fine so far.
So what would you guys advise me to do.
What I have in mind is monitor a bit more, if all fine, try the 9800GX2 again and see if the sound card was causing the card to act up. If the 9800GX2 still acts up then the card is bad. Then it'll be a matter of getting my sound card to work with the rest of the components.
Total Threads = 12
Old 11-01-2009
1) I assume you have reinstalled windows to eliminate corruption issues?
2) How high did you take your PCIE bus?
Old 11-01-2009
issues kept happening, in fact got so bad with new install on different drive that it wouldn't even display correctly.
100, never overclocked it.
Total Threads = 12
Old 11-01-2009
list voltages.
pinch ioh vcore.
Flash bios.
Regarding the vid card, make sure that sucker has enough tim on it.
Old 11-01-2009
list voltages.
pinch ioh vcore.
Flash bios.
well kal everything is at stock. The card does not overheat. I am running a x300 now and I cant pass intel burn test at defaults
Total Threads = 12
Old 11-01-2009
So list them voltages nutterz. Oh and tell us what you did to break it so we can tell you to un-do it, j/k.
So this is out of the blue issues? How is you're bios acting, any squirly action? Anything we need to know about behavior prior to the start of issues?
Old 11-01-2009
Ol'Bud Ol'Bud is offline
Ol'Bud is just getting started
Ok
The eldergeek is here and DO what I tell you to do ,
ALL of it.
Go to the device manager and uninstall all items giving you trouble.
if you do not have a driver un-installer go to piriform and get the lite version of CCleaner , English no Yahoo tool bar.
And keep that on your machine all the time.
Once that is installed re-boot and run the application by going to tools and find the drivers to uninstall.
Then reboot
If you do not already have your drivers copied from the support disk to a folder on your HDD,
Then do so before you start the process I gave you to do.
Then after removing all the drivers and uninstalling all the devices,
That's when you re-boot and get the devices recognized in the device manager by clicking the top of the list and telling the system to search for new hardware.
Sit and wait while it searches and don't get anxious about the time it may take.
If you interrupt the process you will have to start over.
Piriform - Products
http://www.ccleaner.com/download
look down under other builds get the lite version only.
Post back
Old 11-01-2009
Originally Posted by Ol'Bud View Post
Ok
ALL of it.
Then reboot
Piriform - Products
Post back
Thanks a lot for the info guys.
So far what I did is un install my soundcard and all Creative related software including drivers.
So far I have ruled out RAM/CPU. Memtest runs succesfully and I just passed 100 passes of Intel Burn Test. I just got me a multimeter so next up is to see what's up with the PSU. If that shows fine too I'll put the GX2 back in there and test that.
Total Threads = 12
Old 11-01-2009
Well guys I have just tested the PSU at least off load. Everything is well within specs. tested the molex connectors, cpu 8 pin and the 24 pin. So I will uninstall all the ati drivers and give the 9800gx2 a go with no soundcard. Wish me luck! ______________
Total Threads = 12
Old 11-01-2009
A corrupted graphics driver will screw-up your life.
Especially WHQL drivers.
You have to un-install them and do it over.
