Old 10-14-2009
Default Kingpin Cooling Contest
http://kingpincooling.com/forum/show...4&postcount=42
Originally Posted by K|ngp|n
Get your LN2 dewars and benching partners ready Monstru and everyone else interested in winning a full set of pots. This time, it's going to focus more on gpu overclocking and we are going to remove the cpu from the picture all together to make this more inclusive.
Ok the contest begins as soon as I make the thread in the next day or two and ends on OCT 31st MIDNIGHT Eastern Standard time, NO EXCEPTIONS. Submissions must be made to BOTH the contest thread here at the site AND Futuremark.
Any submission for this contest MUST INCLUDE:
Screenshot with background watermark I PROVIDE AT THE START
Valid ORB link using fm approved drivers
Picture of the WHOLE setup being benched DURING runs for contest
Dont have a digital camera? Go join another contest..
Your results will be scrutinzed by those that know whats up with bullshit scores, so don't try any cute stuff like disabling features in the benchmark or forcing the hw or benchmark to run in ANY WAY other than it was intended, mipping, modifying screenshots, etc.
Platform/cpu will be bloomfield/lynnfield corei7 @4.75ghz cpu frequency limit + any compatible mobo. Benchmark and gpu details to follow when I make the contest thread
Old 10-14-2009
hmm.... sounds interesting, would like to see more details.
I don't need anymore GPU pots tho LOL
Old 10-14-2009
I'm pretty sure I'm good with 2 koolance and 2 kingpots.
Old 10-14-2009
I need some GPU pots though, hope every1 ignores the contest coz they already have the pots, lol, :p
Old 10-14-2009
I'm sure everyone and their uncle will be in this competition.
Old 10-15-2009
Depends on what the GPU hardware requirements are.
If its going to require Multi New GPU's then I am not gonna to be in. The just had a 3DMark05 Low Clock contest on XS, not all that many can run in these contests with the GPU requirements to even get on the score board.
Old 10-15-2009
2chesapeakes's Avatar
I beleive Vince mentioned it would be a GPU dependent bench. I would assume maybe '03 which scales with multi GPU.
I have been toying around with the LC '05 and must be missing some tweaks at the same clocks as the top spot I am roughly 1500 points behind the leader. I am running my GPU core and Mem higher also with 2x 4870x2. I only have my Cas 6 1600Mhz gskills left as my 2000Mhz cas8 Perfet storms have one bad stick and my Hyper X have 2 bad sticks. '05 seems to respond well to tight fast memory.
Old 10-15-2009
Gunslinger's Avatar
Overclockaholic
Closest I got was 37,000 at 4.14GHz or so. Wish I knew the magic tweak.
Old 10-15-2009
High uncore seemed to have no effect on the bench. I am running higher GPU core and mem OC and just can't figure it out. What do you use for LOD tweak with ATI cards
Old 10-15-2009
What setup are you guys using for GPU's ?
Just 1 GPU or SLI or Quad ?
And of course the latest GPU's out there if I know you two LOL
