Overclockaholics Forums » Hardware Section » Motherboards » Intel » x58 LE possible ram issue
Old 09-15-2009
marcam923's Avatar
Default x58 LE possible ram issue
Ok the issue lies here.
Stock speeds, just ram voltage and timing set, GPU's work great.
Any kind of OC, even just the dummy OC, my cards run at about 20%
In 3dmark 06 - first screen single gtx275, about 100FPS, with any kind of OC about 20FPS?
I am running Corsair DDR3 1333mhz ram, 9-9-9-24 1.5v
I know I know I need better ram for this nice i7 I have...
It will come, in the meantime, I can run Super Pi and CPU benches OC'd with no issues, 10.2 Super Pi 1M at 3.8GHZ
May not be the most stable, but this should not cause my 3D benchmarks to only output 20% unless the ram has that big of a factor, and does not want to run at 1333 or even slightly over.
Evga x58 LE, ram above, i7 920, gtx275, corsair hx 1000
Any input will be great!
Old 09-15-2009
mark did you run the precision OSD to see if the cards were downclocking at all.
Also at stock speeds does it do it?
Old 09-15-2009
Speaking from personal experience don't ever skimp on the RAM. If there is one thing to spend a little more money on it is this in my opinion. I don't think RAM is the issue here though. Have you tried uninstalling the driver and reinstalling it? Sounds like the driver isn't behaving properly to me. I know when I push my cards to hard the driver stops responding and this sounds about what it does. Just taking a stab at it.
Old 09-15-2009
^^^This and also PSU
Old 09-15-2009
Yeah that too.
Old 09-15-2009
marcam923's Avatar
To answer all of the above, cards perform perfectly at stock speeds.
I have tested with both cards separately, to test for a card issue, or PSU issue.
If I run no CPU/RAM OC, I can push the cards until they quit and they perform like beasts.
I have flashed the mobo bios, which improved a couple things, I have cleared and reinstalled drivers.
Must also mention that this was on a fresh install of windows, newest mobo and GPU drivers.
The only questions I have is the Corsair HX1000 is rated at 13A input current.
If I am only running a 10A power cord, mine was missing from my brand new PSU, could this cause the PSU to drop power?
Gonna test in SLI to question the PSU as to this issue.
Old 09-15-2009
sounds like a config issue if its only when oc'd
Old 09-15-2009
marcam923's Avatar
I'm thinking it is def a config issue, or the fact that my ram does not want to run at the rated speeds.
I may contact Corsair and see what they have to say.
Unless the grand master punx can help me getting some settings locked down.
Old 09-15-2009
I dont have my I7 yet.... be gentle :(
I will call you tonight
Old 09-15-2009
marcam923's Avatar
Well I think I may have a PSU issue.
THe power cord leading to my PSU, which is rated at 10A the input power on the PSU is rated at 13A.
I just popped the second card in, after abotu 4 BSOD's trying to get into windows, most with the IRQ_less than or equal to error, I also got a PFN_LIST_CORRUPT
Finally got in, enabled SLI, started 3D 06, 2 secs, then BSOD Nv disp, error.
GOnna stop at Radio Shack and pick up a properly rated PSU power cord, then test this whole theory again.
Meanwhile the PSU cord that runs to the wall (the one in question) was very warm to the touch, pretty sure the PSU was not able to get the power it needs, which could cause the GPU to be underpowered when I try and OC the CPU/RAM, causing a loss in performance, and with 2 cards in and NO CPU/RAM OC, while it would barely start, (hence leading me back to my power issue) when it did start it would barely run.
Will report back shortly.
