Overclockaholics Forums » Overclocking Section » Overclocking » Huge problems overclocking GeForce 6200 AGP
Overclocking Air & Water...
Old 08-26-2009
Josifek Josifek is offline
Josifek is just getting started
Default Huge problems overclocking GeForce 6200 AGP
Hi all,
i am having terrible problems OC'ing my Geforce 6200 AGP. The default clocks are 350/500 and i am trying 450/500 with a vmod. The problem is that my clocks always return to stock when loading a 3D mark test or a test gets stuck in the middle. I dont see any artefacts and i dont have a vdrop or a OCP problem. Just the &*"!°? drivers. I tried 77.xx drivers, 99.xx drivers and 163.xx drivers and the problem is always the same... I also tried different versions of Riva tuner and the problems presists... I also tried flashing the bios changing the 3D clocks and i get artifacts when entering windows... Well more than artifacts i see only random dots on the screen... When i enter win in safe mod or i dont have drivers installed everything works fine in 2D. Any ideas ?
Old 08-26-2009
Try a smaller OC? 30% is HUGE for a vid card
Old 08-26-2009
I dont think that OC is the problem... Ppl pull over 600 on NV43 core which has more pipelines and resistors... This is a "ECO" core that can run in passive mode... I have seen 720Mhz on core on this particular card...
Old 08-26-2009
It might be a cooling problem. Have you check the heat sink mount?
Old 08-26-2009
i agree it sounds like temps
Old 08-26-2009
Temps under 30 degrees, i mounted a HR 05 chipset cooler on it with a high RPM fan...
Old 08-26-2009
Problem solved: I used the "Force performance level to 3D" in riva tuner so the stupid drivers dont change the frequency and everything is perfectly stable now at 575/760
Old 08-27-2009
Nice Josifek, Glad you solved it.
