Overclockaholics Forums » Hardware Section » GPUs » Nvidia » GTX 285 SLI and 3DMark01 issue
Old 08-23-2009
Afterburner's Avatar
Afterburner Afterburner is offline
Junior Addict
Afterburner is on a distinguished road
Default GTX 285 SLI and 3DMark01 issue
I hope this is being asked in the correct category!
I have posted this same question elsewhere and have not yet received and answer. I am trying to get my WAR's runs in and am failing badly
Here is my cut and paste....
Well I have tried for a day and a half... With no success. So I must be missing something simple and I am hoping someone can help me....
I can make Vantage runs all day long!!! But I cannot run 3DMark06 or 01... In 01 I get the error in the pic below.... 3DMark06 simply says an NOS or NOD have failed and will not start....
Tried new drivers.. Old.. Restart... No overclocks.. Overclocks.... Everything but re-installing the programs.... Sigh....
Any ideas? Thanks!!
#1... 800D | x79 DARK | 3930K | 2133 Gskill | 780 ACX CLassified Surround | 3x ASUS VG248QE 144Hz | EVGA Classified SR-2 1200W
Obutto Cockpit
Old 08-23-2009
like i said in your other thread AB have you tried it in another OS, I had that error in Vista and Win7 beta
Old 08-23-2009
Try uninstalling and reinstalling.
Old 08-23-2009
Junior Addict
@ punx.. I completely miss understood your other post!!! I thought you asked me what I was running... Gotcha! Can do....
@ DrNip.... On that right now.. will try that first!
Obutto Cockpit
Old 08-23-2009
I had this happen to me but I don't remember on what OS or what I did to fix it as I have too many hdd with too many OS's on them. Apparently it was fixed as I don't have the issue anymore.
Old 08-23-2009
Junior Addict
Ok.. Well I just tried to install Punx XP OS.. Failed telling me no HardDrive found..... No I remember why I am using the Vista in this WARs.... I cannot get XP to install.... I am running the RAID0+1.....
Does anyone have an XP with the Classy needed drivers ISO'd? So I can download/burn it? I have my own legit product keys for every single Windows ever released... (2000-XP PRO's for example...)
Obutto Cockpit
Old 08-23-2009
Why don't you just pop the Classified disk in and load them from there or am I missing something here? Better yet I am confused on the no hdd found when trying to install XP. If that is the case what are the drivers going to do for you as that wouldn't be the problem?
Old 08-23-2009
Junior Addict
Well I have tried so many times I got frustrated with it. For some reason even with my own created ISO's I have not found a way to successfully install XP after I have Vista on a RAID0+1..
I can however do it on a RAID0 only... I am so confused....
Anyway... I figured out my issue. It is 100% all me messing up. I failed to change the compatibility to XP ... Now it is working great on the Vista install.... Sucky 44723 score.... but running! http://service.futuremark.com/compare?2k1=9521218
Obutto Cockpit
Old 08-23-2009
ddi you install the raid drivers (F6) ?
Old 08-23-2009
Junior Addict
I have tried countless times... That is why I did an ISO hoping it would help. It gives me the same exact error each time.... Keep in mind I even tried my XP RAID0 ISO I installed in my business system...
Obutto Cockpit
