Originally Posted by Neuromancer
Oh yah, tighten that stuff up
Looking good though, always loving playing with new tech
Yah, I'm familiarizing myself with the bios and starting to research i7, late to the party but usually have the most fun.
Originally Posted by DrNip
Word of advice, take your volt measurements from the mobo so you know what thy are so you can properly tune them into BIOS. Mine are pretty close to what Eleet reports except my RAM. It is .05v off from what it reports. So a setting of 1.6 in BIOS is 1.65 in Windows.
Where are you measuring from?
Originally Posted by ocgmj
Maybe shoot for 8-8-8-20?
I'll start tightening it up a bit, tried runnign the xmp1 profile at 2133 mhz w/auto timings, it hangs.
Originally Posted by Chuchnit
Hell no, try 7-7-7-18-5-60-1T to warm up. Those are 2133 bin elpidas cool2
I noticed that an unstable boot will hang on post codes but if you hit restart button, it'll push thru to the operating system and crash there. Just need to tweak the voltages I suspect. Whats an above average bclck?
I am interested in seeing what that bad boy of a cpu you have does.
All the voltages are on auto cept the dimm which is at the rated 1.65v. The vCore seems a bit low but it ran 32m easy breezy.
