Overclocking Air & Water...
Old 07-27-2009
Cecil Cecil is offline
Cecil is just getting started
Default HT vs No HT
Going to do some testing of 20x linX HT stable 24/7 speeds, vs the same without. With HT, 4.2HT is my 24/7 setting, with max temps at 74C, fans at silent settings. Once I find my non HT settings that matches, Ill start testing. So far at 4.4.
Old 07-27-2009
74C? LOL what you running a prescott?
Old 07-27-2009
Huh?
920 at 1.38Vcore under load with HT on, and fans at ~600RPM. With them turned up its in the low 60s.
Old 07-28-2009
Your a lucky man Cecil to run those temps. I would be at 74 with fans turned up high. Prolly because the room I am in has a higher temp than the rest of the house. Keep us posted on this study of yours!
Old 07-28-2009
Originally Posted by Cecil View Post
Huh?
sorry, was just kidding around
Old 07-28-2009
Neuromancer is currently on probation due to his violation of Forum Rule Section 8 sub-paragraph (b) which reads:
Thou shall not post while intoxicated!
Old 07-29-2009
Well, final speeds are 4200HT, and 4410 no HT. Both load at 74C with fans at silent, and my AC off. And neither go over 1.375Vcore.
Will start adding results soon. The idea of this is to see if its worth running a lower speed with HT for 24/7 use.
Old 07-29-2009
Non HT testing
210x21 - 4410Mhz - 6gb tri-channle - 1680Mhz - 8-8-7-21-1t
Wprime 32m - 7.13
Wprime 1024m - 225.546
Super Pi 1m - 9.204
Super Pi 32m - 8m 27.313s
3dmark06 -
3dmark06 CPU -
3dmark06 SM2 -
3dmark06 SM3 -
3dmark Vantage -
3dmark Vantage CPU -
3dmark Vantage GPU -
PCmark Vantage -
xH264 Benchmark -
WinRAR Large File -
WinRAR Small File -
Crysis Benchmark CPU -
Old 07-29-2009
crustytheclown's Avatar
EXTREME NOOB...
I run with HT on - it helps me with some heavy multitasking and some multi-core programs I use, despite the higher temps.
Old 07-29-2009
sofos1990's Avatar
HT on is better. On winrar benchmark the performance is amazing, if I remember well is 30% faster! BUT the temps are higher!
With HT off the temps are lower, BUT you can get more Mhz!
I've also heard that some guys prefer HT on, because it gives them more stability on high Mhz
