RAM DDR, DDR2, DDR3 & Beyond... |
07-22-2009
Corsair Re-launches Dominator GT Ultra-Performance DRAM Modules
Corsair, a worldwide leader in high-performance computer memory, power supplies, and flash memory products including solid-state drives, today re-introduced the popular Dominator GT line of memory modules. These modules had been removed from the market due to unacceptable failure levels of the Elpida "Hyper" components with which the modules are constructed.
"The issue with the Hyper RAMs was discovered with the help of the enthusiast community, and we worked closely with them to solve it," stated John Beekley, VP of Applications Engineering at Corsair. "Our lab was able to correlate the failures to specific batches of early material, we worked very closely with Elpida to determine the root cause of the issue and to define the associated corrective actions to take. We are confident that every GT module using the Elpida Hyper IC Corsair ships from today will meet our strict quality and reliability standard."
The Dominator GT memory kits are being re-introduced with updated part numbers, and will be available within one to two weeks. All Dominator GT modules are black with red fins, and include the Airflow cooling fan. Module kits and specifications are as follows:
* 6GB kit for Intel Core i7: Part number CMG6GX3M3A2000C7, available directly from Corsair's web store at corsair.com. Matched set of three 2GB modules, DDR3, 2000MHz, 7-7-7-20 latency timings.
* 4GB kit for AMD Phenom II AM3: Part number CMG4GX3M2A1600C6, available directly from Corsair's web store at corsair.com. Matched pair of 2GB modules, DDR3, 1600MHz, 6-6-6-18 latency timings
* 6GB kit for Intel Core i7: Part number CMG6GX3M3A2000C8, available from authorized Corsair resellers and Corsair's web store at corsair.com. Matched set of three 2GB modules, DDR3, 2000MHz, 8-8-8-24 latency timings
* 6GB kit for Intel Core i7: Part number CMG6GX3M3A1866C7, available from authorized Corsair resellers and Corsair's web store at corsair.com. Matched set of three 2GB modules, DDR3, 1866MHz, 7-7-7-20 latency timings
All Corsair Dominator GT modules are built using the patent-pending DHX+ (Dual-path Heat eXchange) heatsink, which uniquely cools both the front and back of the memory ICs, and the printed circuit board, for greater reliability and increased overclocking flexibility. DHX+ modules also utilize removable heatsink fins, which allows for range of Dominator GT cooling options, including the Corsair Cooling Hydro Series H30 waterblock and Ice Series T30 thermo-electric cooler, which actively cools the modules up to 20 degrees C below ambient temperature for maximum overclockability.
All Dominator GT products also ship with the Corsair Airflow fan as standard, which maximizes airflow over the module's cooling fins, increasing heat dissipation to improve memory performance and reliability.
The new Dominator GT modules will be available within one to two weeks from Corsair's authorized distributors, resellers worldwide and Corsair's web store at corsair.com, These modules are backed by Corsair's limited lifetime warranty. Complete customer support via telephone, email, forum and Tech Support Express is also available.
SOURCE:
http://www.techpowerup.com/99866/Cor...M_Modules.html
I see the top of the line is 7-7-7-20 now. I wonder if they came off any of that price yet?
07-22-2009
Overclockaholic
Now there is some great news. Good to see they found the issue and resolved it in a timely manner.
Good news but no mention of the 3G sets. Are they not going to offer them anymore? Thankfully mine are still good at the moment.
07-22-2009
I wish they would let us in on what the prob was.
07-22-2009
It is pissy being in the dark sometimes...
07-22-2009
Least they got some performance modules flowing again.
07-22-2009
Junior Addict
that is what i am talking about. i honestly had a hunch this would drag out and Elpida Hyper would die off into obscurity but that clearly isn't the case, thank goodness. the best part is the 2000 kit's are now 7-7-7 instead of 7-8-7, nothing like making a come back with a bigger stick
living life 32M digits of Pi at a time...
07-22-2009
Sweet news!!!!
Main Rig
Case - Cooler Master Cosmos S
PSU - Corsair HX1000 1000W
DVD - LG 22X GH22LS30
OS - Vista Ultimate 64bit
07-22-2009
7-7-7, wow
07-22-2009
this is going to be even better it seems
7-7-7- is going to be even harder to stabilise
would be good to know what happened but i dont we will know heheh
