Overclockaholics Forums » Welcome to Overclockaholics » Hardware/Software News » Dual Core Nehalem Corei3 4ghz @ 0.832V
Old 07-21-2009
Default Dual Core Nehalem Corei3 4ghz @ 0.832V
Originally Posted by techpowerup.com
First Intel Clarkdale Core i3 Low-Voltage Overclocking Feat Yields 4 GHz at 0.832 V
Intel's upcoming dual-core derivatives of the Nehalem/Westmere architecture, codenamed "Clarkdale" seems to have some interesting electrical characteristics. The CPU component of the chip is built on Intel's brand new 32 nanometre process that facilitates higher transistor densities, and in the process, intends to bring down TDP. An overclocking feat by Coolaler.com seems to suggest one of two things: either these chips have naturally low vCore voltages, or that the overlocking headroom at low-voltages is exceptional. Coolaler used a pre-release engineering sample of the Core i3 Clarkdale processor on a compatible platform, and achieved 4 GHz of clock speed with the vCore at 0.832 V. The frequency multiplier of the CPU was set at 25.0x, and a bus speed of 160 MHz used. Intel will be ready with these processors by the end of this year.
Source: Coolaler.com
Techpowerup.com
Old 07-21-2009
Deux's Avatar
Deux Deux is offline
Deux is on a distinguished road
There was some discussion when this was posted on OCX a few days ago and several people in the know said that CPU-Z voltage is off significantly for those chips. Still quite impressive though.
He has also posted 5200+ runs on dice. Hopefully these 32nm chips will be able to replace wolfdales as the go to 1M and 01 chips.
Old 07-21-2009
Sounds like it will be a GREAT chip if it can handle 1.5+ volts at least handle it long enough for some new 2D records
Old 07-21-2009
I'm interested in the cold bugs, here.
Old 07-21-2009
Cecil Cecil is offline
Cecil is just getting started
Link says Core i5. Also, Intel said HT will be on i7s only, and there will be some i7s on LGA1156. They need to make up their mind
Old 07-21-2009
More importantly, a post in the link says:
Old 07-21-2009
Outlaw Outlaw is offline
Outlaw is just getting started
LMAO
Intel E8600
XFX260GTX
Corsair 750W
Asus Max Formula
D-Tek V1 CPU water Block
Kingston HyperX PC8500 4x1g
XSPC Full Coverage Video Card block
All tucked in my ThermalTake full tower
Old 07-21-2009
69_Goat's Avatar
69_Goat 69_Goat is offline
Now I would say that's more than a little off topic, Supes.
Old 07-21-2009
Old 07-29-2009
crustytheclown's Avatar
EXTREME NOOB...
HEehehhe, you guyz are crazy!!!
I would LOVE to see a non-existent cold bug in these...AMD style...It would REALLY be something
