07-20-2009
Enermax Appolished Series Fans
Originally Posted by techpowerup
Enermax Rolls Out Apollish Series Coloured Fans
Power and casing specialist Enermax released its Apollish series of coloured case fans. Available in standard 120 mm (model: UCAP12), and 80 mm (model: UCAP8) sizes, the fans have two attractive features apart from one which enhances its functionality. To begin with, the fans come in four colours: red, blue, silver, and green. Apart from being translucent, the fans have a chrome sputtering coating that gives a metallic sheen. Illumination is care of a patented circular LED design that gives it brilliant, radial streaks of light. In terms of functionality, the fans feature the company's twister-bearing design that extends product life. These fans are rated to serve for 100,000 hours. UCAP8 spins at speeds between 600~2100 rpm, pushing 12.48~33.04 CFM of air, while the UCAP12 spins at speeds between 700~1700 rpm to push 28.98~71.76 CFM. Both fans have a rated minimum acoustic footprint of 15 dBA. The UCAP8 and UCAP12 Apollish fans have recommended price tags of $13 and $19.5 respectively (before applicable taxes).
Source: Expreview
Techpowerup
