Old 07-19-2009
Default Kneeded Eraser Brands
Starting this thread to get a feel from users about the differences between kneeded eraser manufacturers/brands.
-What brand do you use? Link it
-Is it more or less maliable (soft or difficult to mold?)
-Difficult to remove after extended sub-zero sessions
-Needs to be heated a lil to easily remove from the motherboard
-Any other observations, conclusions you've drawn from comparing brands
-Its cheap and it works......
Old 07-19-2009
i dont have any packaging for mine... will go buy another one from "Joann's" (a arts and crafts store)
and let you guys know as I know mine has worked great for multiple applications now without issue
Old 07-19-2009
Afterburner's Avatar
Afterburner Afterburner is offline
Junior Addict
Afterburner is on a distinguished road
Where do we get them? Arts and craft stores? Drafting supplies maybe?
#1... 800D | x79 DARK | 3930K | 2133 Gskill | 780 ACX CLassified Surround | 3x ASUS VG248QE 144Hz | EVGA Classified SR-2 1200W
Obutto Cockpit
Old 07-19-2009
sofos1990's Avatar
In Greece we can buy them from bookstores. If I know well Kneeded Eraser is used by painters, designrs etc...
Old 07-19-2009
AB you can buy them at any art/craft store
Old 07-19-2009
BustaH BustaH is offline
BustaH is just getting started
Its in the uk but this brand is the best I have found, very plyable and stays that way [does'nt dry out]
http://www.artifolk.co.uk/catalog/pr...ded_eraser.htm
Old 07-20-2009
I use General's and you can pick it up at the cash registers at Hobby Lobby.
-Is it more or less mailable (soft or difficult to mold?)
It is like play-do but with a little harder feel to it.
Removal is a breeze. Usually comes off in several pieces but nothing too tough.
Haven't tried heating it.
This is the only brand I have tried.
It is cheap though the price went from $1.39 to $1.69 still cheap.
Old 07-20-2009
Same stuff as I use. Tho I think just about any brand of the kneaded eraser should work fine.
Old 07-20-2009
There are other brands at Hobby Lobby but you get less for the same if not more price. That is what is the deciding factor for me.
Old 07-20-2009
sofos1990's Avatar
I'm using these....
