Hey fellas
I seem to be in this perpetual "testing" mode but i tell you what, I love it. Getting the end results is nice and all but getting to it is even more fun.
Always great to talk(&pick his brains) to my mate youngpro during these sessions :up: who is about to unleash a storm from downunder so watch out for that.
Good to always catch up with the usual suspects during benching you know who you are :p:
So in my preparation i've battling with the following components in intial stages
Test Configuration:- EVGA CLASSIFIED E760 (S610 bios)
- Intel Core i7
- 6GB 2000GT Corsair Dominators CAS7 DDR3 > Week 22, 2009
- Asus 4870X2 Graphics Cards
- 1000W HX1000 Corsair PSU
- 1hp C-BuZz Single Stage (kayl evap)
- 160GB IDE Hard Drive
- Windows XP Pro 32bit SP3
excuse my non-fancy photochop skillz :p:
The purpose of all this testing i guess it to be able to at least get a rough idea what sort of settings i will have a chance to try on LN2 before i start going cold.
I like to pretest on SS to not waste LN2 i guess and i get to concentrate on what i'm doing a lot better than having to pour LN2 all the time.
Wasting money also makes no sense heheh :p:
My first concern was 2:10 RAM ratio. This ratio sucks on my Gigabyte X58-UD5.
I just couldn't get any decent clocks out of RAM past 1GHz with this ratio.
Why this ratio? Well i'm working with 25xmulti so i've got a couple of options here, to go to 2:8 CAS6 which is fine or 2:10 CAS7 which is better as i can max out the RAM as well at top clocks.
There is always the 23x multi as well which i will explore but i'll be battling BCLK here so why not start with easier setup first heheh
I'm hoping to be able to stabilise 32M SuperPi at 5.5GHz so I'll need to be able to run 220MHz bus stable right
OK so lets start there
220MHz bus stable with CAS7 2:10 RAM ratio running at 1100MHz 7-8-7-21-1T
Always start with the good old 32M SuperPi
What about 3DMARK01 >> some of the tests in 01 can be pretty taxing on system itself
can it handle , cars, lobbies, dragos >> YES IT CAN
(starting to sound like Obama
what about 3DMARK06
no dramas
sorry i'm just laughing at myself now
If i needed say 5GHz + NB speed
can it handle that
hell yeah
Let's bump it up (for insurance puporses only) hehehe
224.4MHz bus stable with CAS7 2:10 RAM ratio running at 1122MHz 7-8-7-21-1T
hmmm 224.4 * 25 = 5610mhz grrrrrrrrrr fingers crossed hehehe
32M SuperPi = Done
AM3 can sometimes be a biatch with RAM going too hard
not here
3DMARK06 ... looks good
will it do 1132MHz 7-8-7-21-1T.........hell yeah but now i'm just getting greedy . i dont want to push more cause i'd be devastated if these modules died
This is all nice and dandy at -50C. Now i have to repeat this at -130C with 25x multi heheheh
Anyways i've still got plenty more testing ("fun") to do so i'll pop in if any updates occur
If you'd like to try my settings i've got the bios template attached
Let me know if it works for ya or if you have any suggestions i'm all ears
Mother Board Template( EVGA X58 Classified E-760 )
Code:
Frequency Control
CPU Clock Ratio ( 21X )
CPU Host Frequency (Mhz) ( 204 ) to boot
MCH Strap ( Auto )
CPU Uncore Frequency (Mhz) ( 4080Mhz { 20X } )
CPU Clock Skew ( 0 ps )
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 107 )
Memory Feature
Memory Speed ( Default )
Memory Control Setting ( Enabled )
Memory Frequency ( 1020Mhz / 2:10 )
Channel Interleave Setting ( 6 Way )
Rank Interleave Setting ( 4 Way )
Memory Low Gap ( Auto )
tCL Setting ( 7 )
tRCD Setting ( 8 )
tRP Setting ( 7 )
tRAS Setting ( 21 )
tRFC Setting ( 72 )
Command Rate ( 1t )
RTL 57-59-61
(Leave at Auto & tune a little)
Voltage Control
Extreme mode 2
EVGA VDroop Control ( With VDroop )
CPU VCore ( 1.5 )
CPU VTT Voltage ( +325 ) 1.512v DMM measured
CPU PLL VCore ( Auto ) > 1.335v DMM measured
IOH PLL VCore ( 1.65 )
DIMM Voltage ( 1.76 ) DMM measured 1.761v
DIMM DQ Vref ( +0mV )
QPI PLL VCore ( 1.5 )
IOH VCore ( 1.5 )
IOH/ICH I/O Voltage ( Auto ) ~ 1.5v
**VTT PWM Frequency ( 610 KHZ )
**CPU PWM Frequency ( 1333 KHZ )
**CPU Impedance ( Less )
**QPI Signal Compensation ( Less or Auto )
ICH VCore ( Auto ) ~ 1.05v
CPU Feature
Intel SpeedStep ( Disabled )
Turbo Mode Function ( Disabled )
CxE Function ( Disabled )
Execute Disable Bit ( Disabled )
Virtualization Technology ( Disabled )
Intel HT Technology ( Disabled )
Active Processor Cores ( All )
QPI Control Settings ( Enabled )
QPI Link Fast Mode ( Enabled )
QPI Frequency Selection ( Auto )
OC Recorvery ( Default )
many thanks to EVGA for the board and a quick RAM replacement for my dead kit of Eplida based Corsair Dominators
