Overclockaholics Forums » Hardware Section » Motherboards » Intel » Foxconn Flaming Blade series
Old 03-06-2009
Default Foxconn Flaming Blade series
Foxconn Makes Flaming Blade X58 Series Official
Pictured last month as merely a low-end variant of the Blood Rage X58 series (read here), Foxconn Flaming Blade X58 has emerged as a product series in itself, with two sub-variants: Flaming Blade X58 and Flaming Blade X58 GTI. The former being the base-model, while the latter is a scaled-down, even cheaper one.
Both motherboards feature an identical feature set for the most part: Three DDR3-1800 DIMM slots, two PCI-E x16 slots, near-identical board layouts, etc. The differences start with the GTI variant featuring simpler component cooling, with individual heatsinks over the chipset and VRM areas. The base-model has a heat-pipe based cooler. Another set of differences are present with the boards' back-panel and the connectors on offer: the GTI variant lacks two eSATA connectors and an Ethernet controller (although the picture suggests otherwise). Both models will cater to the $200 market price-point.
Source: TechConnect Magazine
I'm almost tempted to buy it just for the flames,
