Old 07-01-2009
karmakazi's Avatar
Talking Rampage Extreme+8200=?
Hey guys got a 8200 a while back and decided to see how she would fare under LN2. I dont have screenshots handy so I will reference hwbot.
SETUP:
E8200 (will get batch after I break down setup) // cooled by duniek pot @ -120 to -130°C, CB@-136°C
Rampage Extreme Bios 1104 // northbridge cooled with thermalright hsf
2x1GB Corsair Dom 1800Mhz C7D's
2x1GB Kingston Elpida Hyper
Samsung 1TB sata
WD 36GB Raptor sata
ATI X800 video
Voltages: For 650fsb boot from Bios
1.91vCore
1.63vPLL
1.57vTT
1.83vNB
2.14vDimm (using corsair D9's not elpidas)
First I took a whole session dedicated to feeling out the chip and finding best settings.
Then next session I installed my 32M 2k3 OS and on the first run knocked out the Gold . I also got a few backups in case someone tries to dethrone me
http://www.hwbot.org/result.do?resultId=868883
2k3 isnt as good for pifast or 1M but I gave those a shot too. Ended up with 5th 1M and 4th Pifast.
Attachment 444Attachment 446
Next session will be in XPSP3 with fully tweaked pifast and 1M runs. I hope to grab golds for both there... Then lastly I will load vista and try out wprime and pcmark05/vantage. I have some ACARD 9010 lovin' to give this cpu hehe
Will update the thread as things progress,
Jamie
Old 07-01-2009
damn, 5ghz! and where'd that screeny come from??? to_keep_order
Old 07-01-2009
karmakazi's Avatar
Check pifast... 5200Mhz
Thanks for that SS im lazy to printscreen off the bot
Also a tip: anyone using a 1M modded bios (to give unknown cpu boost) do not bench pifast with it. Scores suffer a little
Old 07-01-2009
Top Secret Hack:
Code:
Click screeny at bot, right click screeny when it comes up, save picture as- to your hdd, come back to forum, click paperclip icon on post, upload from hdd, maximum ownage ensues
No prob bro, u one of the good guys, I'll pick up ur slack anytime
Old 07-01-2009
karmakazi's Avatar
Top Secret Hack:
Code:
HACKER!!! Thx tho.
I also wanted to thank Before for the 1M modded 1104 rampage extreme bios.
Old 07-01-2009
2chesapeakes's Avatar
HACKER!!! Thx tho.
What is this 1m modded bios and why have I not been sent it?
Old 07-01-2009
HACKER!!! Thx tho.
I can thank you Now, if you send me that bios
Old 07-01-2009
karmakazi's Avatar
Here is the link, again ALL credit goes to Before and the guys at IxTremeTek forums. I have nothing to do with it
It amounts to a .15x second boost in 1M. Dont even waste your LN2 trying 32M on it tho it will kill your times. Its also only functional for 45nm wolfdale procs. Wont work with older stuffz
Old 07-01-2009
Bad karma, linky non-worky
Old 07-01-2009
Wow. Very nice. Almost a 100% overclock!
