Overclocking Air & Water...
Old 06-29-2009
Question Waza/CDT tweaks
Well since some of you super pi champs like 3OH6 is here I figured I'd ask. I'm not asking for your secret sauce waza file size or anything. I would just like a clear explanation of exactly what it does and why it helps 32m? I've played a little with superpi tweaker but have no clue on where to start adjusting the proggie. For some of you hardcore guys, yes I know that it is posted places like the xs lc thread, but I honestly don't have enough free time to sift through 200+ pages in a thread. Plus I don't think I've seen anyone explain how/why it works.
lemme say once again.... I don't expect you to share your waza file size or how many times you do it. Just a little how to and why to do it. I already know to play with page file and maxmem tweak.
Thanks Chuchnit
Old 06-29-2009
Ok so no one wants to share. So then explain why its done, not how. Or hell just link it up to where you learned.
Old 06-29-2009
dinos22 dinos22 is offline
dinos22 is just getting started
lol you're not a patient type are ya hahahah
wazza has been discussed to death and back at XS
you really should just do a quick search there and find plenty of material to read up
essentially you want to make your HDDs work hard for a little while and then do the bench basically
most ppl just copy a file from one partition to another and thats that
wazza has lost a lot of its charm with high L2 cache CPUs as gains are very small now though but yeah thats that
Old 06-29-2009
3oh6's Avatar
3oh6 3oh6 is offline
Junior Addict
3oh6 will become famous soon enough
Dino is right, copy wazza doesn't have near the effect on i7 as it use to due to the massive cache on these chips. my understanding of wazza has always been that it is a process which ends up clearing the CPU cache - or 'aligning it' - letting SPi room to run free thus increasing the calculating speed. with the cavernous cache of i7, this just isn't as effective.
most setups from what i have seen on i7 only gain 3-4 seconds for 32M from wazza. with that said, i haven't really sat down and tried to optimize my wazza method for i7. i am still running my basic setup from the first E6300 C2D's i had. i know, i know, shame on me
Old 06-29-2009
i am thinking that it may be even less than that but i am probably not doing it well enough either heh
Old 06-29-2009
<<HANNIBAL>>'s Avatar
<<HANNIBAL>> <<HANNIBAL>> is offline
<<HANNIBAL>> is just getting started
Just type this in RUN: fsutil file createnew D:\wazaaa.dat 1941504000
it will create a file in your partition D:
then copy the file in the SPI folder and after that run SPI 32m
Old 06-30-2009
I'm not impatient Dinos. I made that remark becuase I know waza method is closely gaurded by some. Yes I have a link to an xs thread in my favs, but it's over 100 pages to go through. Not to sound lazy, because every tweak I know has included countless hours scouring xs and i4memory for the info. I just don't have time with a newborn and all to read up on it. Super Pi has kinda grown on me and I figured I'd try learning it a little.
Sweet Jody!! Thats really what I was looking for. Just the general jist in laymen terms.
It all good. You make up for it in raw horsepower
Thank you very much HANNIBAL
Old 06-30-2009
Good to know as I tried it on my i7 and didn't see the gains others reported. I was startin to think I was doin somethin wrong.
Old 06-30-2009
3oh6's Avatar
Junior Addict
i think he said that because you bumped the thread after 3 hours because no one replied yet
no problem, but don't quote me on the actual reason for why it works, that is just my understanding...keeping in mind i never really cared why, just how to make it work best
living life 32M digits of Pi at a time...
Old 06-30-2009
I inderstand. I just saw the views and figured no one wanted to share.
I guess I'm wierd. I kinda like to think I understand what Tweak i use is doing behind the scenes. It gives the the illusion that I know what I'm doing. Not that it really matters but it makes me feel better. Honestly i asked though because i started a guide here (thats sucks) and can't explain some of the tweaks I've heard of or even use. I really need to make the time to do that stupid thing and finish it :(
