Old 06-27-2009
Default cant change sig template
Thought it might have been an issue with Opera browser, but it does not work with IE either.
I have tried clicking the radio button next to the one I want as well as clicking the link "use this template"
any ideas?
Old 06-27-2009
You need to click the "force a refresh" on their server. If that doesn't work then press CTRL+F5.
Old 06-27-2009
Yup I read that.
The closest I can come to changing the sig, is making hte second picture not appear at all.
Then when I right click and open image.. I see the same freaking image!
(that gay blue one in my sig now)
EDIT: started picking them at random, and got your sig.
EDIT EDIT: I like the eluha sig its got my #1 stuff in there (hey I dont have a lot of points yet.. gotta feel good about something :p)
Old 06-27-2009
Sweet. Yeah that was the latest one I made for the team. Simple, clean and to the point if you were to ask me!
Old 06-27-2009
LOL
Found another one I want.
Problem is none of hte black ones seem to work for me. I mean.. not work at all. Like I select them the page reloads and shows "my current" image. Which is not what I just selected ARGH!
Again, the furthest I can get is for the second "current image" to not appear at all. Right click and open image or reload image that empty link, just loads up the drnip sig. Not that it is bad.. mind you just not what I was trying to pick
Old 06-27-2009
Well everytime I go to pic one I select edit then do what I want to it then click use as sig when I am done with it. You don't have to edit it if you don't like but you might try that away.
Old 06-27-2009
yup that worked thanks
Gotta tweak it a little but looks good so far
Old 06-27-2009
Great!
