Old 06-27-2009
Default SSD Shopper's Assist
Hey Gang,
I think its time to get with the times and go the way of the SSD. I already have an Areca-1220 raid card with 8 sata slots. So now I need 8 SSD's to fill them.
I wanna go the cheap but fast route so was considering 8 of these:
http://www.newegg.com/Product/Produc...82E16820609330
Any input or comments or suggestions are more than welcome.
Old 06-27-2009
8!!! Oh only 16GB. I personally think you would be better off with 2-3 Intel X25-M's. They are the best right now.
http://www.newegg.com/Product/Produc...82E16820167005
If not then look into the Vertex's by OCZ. They are a lil cheaper and sell a 30GB unlike Intel lowest being 80GB. Get 5-6 of them.
http://www.zipzoomfly.com/jsp/Produc...tCode=10009849
I've been saying it for awhile and am going SSD this summer or at least on my O/S. I will be goin with one or the other I have listed. Prolly two of the Intel's.
Old 06-27-2009
Intels are the best
I still like my MTRONs tho <hungs>
But it takes like 2 of my MTRONs to = 1 Intel SSD in bandwidth.
I keep trying to get Francios to alow me to step up my MTRONs to Intels. He laughs at me and says... sorry we do not take inferior SSD's LOL !!!
Old 06-27-2009
Reading material: http://www.storagesearch.com/ssd-fastest.html
Old 06-27-2009
Yup, my next toy
http://www.storagesearch.com/ssd-23.html
Old 06-27-2009
I double dog dare u!
Old 06-27-2009
You know about my SSD;s so i will say this. OCZ drives rock. Yes they are expensive and i have no regrets. Their support forums are awesome. But if i could do it again i would go with these. They are slc drives and are super fast. The 60gb and under are usually mlc drives. I think 2 of these would come very close to my 4 60gb drives. Do you plan on using your onboard RAID? With any luck you have a ICH10 controller onboard.
OCZ 120gb SSD's
Old 06-27-2009
Double check the specs on your card, IIRC the areca 1220 basically makes out at 3 or 4 SSDs.
More SSDs will give you more storage space but no more speed.
I will try and find the link.
Click me!
Found it, it is from Dominick32's website.
Old 06-27-2009
The 120GB Vertex's are better than the 30GB I listed.
Old 06-27-2009
OCZ 120gb SSD's
Nope to onboard, I have an Areca-1220 8 sata port raid card to use. Which SSD's are u suggesting?
