Air Cooling Air Powered...
Old 06-21-2009
Default Xigmatech "Thor's Hammer"
Picked up this cooler to be part of the "Air" testing phase before giving motherboard's the seal of approval. I chose this cooler because the mount listed said both "S1366" & "S775".
Here are some product images since they take such nicer pics than me:
First impressions of the overall looks are impressive. The rubber fan mounts look good. After fumbling around a few days procrastinating, I realized that this mount system isn't really what I was looking for in a quick "Air" test system, but that was my bad in choice. I'm a quick-change sorta guy, thus all the koolance quick disconnects in my rigs. Alas, I'll be firing her up soon and running an E8600 thru its paces on a REX. Will post back soon.
Old 06-21-2009
That is a very nice looking cooler.
But that mounting system looks very hard to get setup correctly.
Looking at the Classified I can where it would almost impossible to tighten those mounting screws with that little wrench.
I like the way the V8 is mounted, tighten up the mounting screws from the back side makes it very easy to do.
Old 06-21-2009
I'm gonna see if some of the other water cooling mount stuff, screws plates that will make this an easier "quicky" h/s for me.
Old 06-27-2009
marcam923's Avatar
Results!!
Hopefully I can have some of my own soon.
Old 06-27-2009
Sry Marc, got caught up in another build. So far with this h/s I get 28ish idle @ 4.5ghz and 1.3vCore and around 55c load I believe it was. Bench stable but limited extensive testing done.
E8600 + RE
Old 06-28-2009
Vivi's Avatar
Vivi Vivi is offline
Planning my comeback..!
what batch E8600? have u tested on Dice yet?
Old 06-28-2009
The plan is to pick up some Dice on Monday and let her rip. Batch# Q843B386 SLB9L
been caught up giving things away to awesome members
Old 06-29-2009
westsider westsider is offline
westsider is just getting started
one of the best optics here from xigmatek
i like this cooler
Old 07-13-2009
youngpro youngpro is offline
youngpro is just getting started
thats a impressive looking cooler, how is the mount kit, looks a little fiddly?
