Overclocking Air & Water...
Old 06-20-2009
Default wPrime
I just went to list my benches for wPrime, thought it seemed like it took longer than it should have
38 seconds 32m
and
1236 second 1024m
system is
4GHz dual core AMD
211x19
1600ish HT link
2530NB
822MHz 4-4-4-12-16-1T GSkill ram
Vista 32
60GB partition on 500GB WD Black HDD
WTF? Instability, or something else?
Old 06-20-2009
hellcamino's Avatar
Did you go into the advanced settings and set the number of cores properly?
Old 06-20-2009
LOL I just figured that out thanks
down to 18 seconds.
still slow. but I am working on that
Old 06-20-2009
Its why we're here bro, to lend a helping hand
Old 06-20-2009
FYI, use the submit button to auto-matically submit wprime runs to hwbot. Once there, login if necessary, then click the edit button on the submission and enter any fields that are blank, make sure to upload a valid screenshot of the run too.
Old 07-01-2009
G H Z G H Z is offline
G H Z is just getting started
Good advice, we get tons of complaints @ hwbot for results that have validation only...which btw is valid @ hwbot.
Old 07-01-2009
Everybody loves them screenys, feed the pic monstes of the world :dancinwolf:
Old 07-03-2009
ViViD ViViD is offline
ViViD is just getting started
Hi All
What Ur Advise For Wprime 32M To Get Me Into High Score With Q9550 Intel?
I Set 9:30Ms With Hardly Work On Water This Link
In vista 64Bit What Can I Do For Give Lower Second?
Old 09-07-2009
Chicken Patty's Avatar
38 seconds 32m
and
1236 second 1024m
system is
4GHz dual core AMD
211x19
1600ish HT link
2530NB
Vista 32
Hey buddy, check this thread out if you'd like, you can do some comparison to other rigs there.
http://forums.techpowerup.com/showthread.php?t=77369
Total Threads = 12
Old 09-13-2009
Phenom II 550BE
MA790XT-UD4P
Water/SS
http://www.hwbot.org/result.do?resultId=897140
http://www.hwbot.org/result.do?resultId=897492
http://www.hwbot.org/result.do?resultId=897388
http://www.hwbot.org/result.do?resultId=897480
