Overclockaholics Forums » Hardware Section » CPUs » Intel » Skylake De-lidded
Old 08-10-2015
Default Skylake De-lidded
SOURCE
Intel Skylake De-lidded, Reveals Tiny Die
by btarunrSunday, August 9th 2015 18:56 Discuss (70 Comments)
When Japanese tech publication PC Watch got under the hood (lid) of a Core i7-6700K quad-core processor, what they found was an unexpectedly small silicon, that's shorter in proportion to its width, than previous dies from Intel, such as Haswell-D, and Ivy Bridge-D. It's smaller than even the i7-5775C, despite the same 14 nm process, because of its slimmer integrated graphics core with just 24 execution units (compared to 48 on the i7-5775C), and the lack of an external 128 MB SRAM cache for the iGPU.
The substrate Intel is using on the i7-6700K was found to be slimmer than the one on the i7-4770K, at 0.8 mm thick, compared to 1.1 mm on the latter. The thicker IHS (integrated heatspreader) makes up for the thinner substrate, so it shouldn't cause problems with using your older LGA1150 coolers on the new socket. Intel is using a rather viscous silver-based TIM between the die and the IHS. The die is closer to the center of the IHS than its predecessors were. PC Watch swapped out the stock TIM with Prolimatech PK-3 and Cool Laboratory Liquid Pro, and found some impressive drops in temperatures at stock speed (4.00 GHz) and with a mild overclock (4.60 GHz).
Old 08-12-2015
http://www.pcper.com/news/Processors...6700K-Delidded
