Overclockaholics Forums » Software Section » Vista » Vista 64 4gb hotfixes
Vista The Comeback Kid...
Old 06-14-2009
Default Vista 64 4gb hotfixes
Just a couple:
Memory Allocation problems:
http://support.microsoft.com/kb/940105/
SLI Rigs (Dual VCards):
http://support.microsoft.com/kb/936710/
Old 06-14-2009
Thanks for sharing. These fixes have all been added with the latest service pack for vista.
Old 06-14-2009
Unless you have the service pack on your install disk or sliptreamed, you'll wanna gun these after getting into windows to finish up installing other items. OR you can wing it with 1 stick.
Sometimes you can get away with an os install with 4gb but once in windows you get instability. So if you wanna continue to run 4gb while you upgrade to whichever service pack, you'd run this. NO?
Old 06-14-2009
hellcamino's Avatar
I have an old retail version of vista Supes and it actually works fine if the machine is stable, I do of course install the service packs straight off though. With a pair of 4870X2's and 6gb of ram in my current pc as well as the cache from 6 hdd's, I would have to dismantle my pc to get under 4gb total installed memory.
Old 06-14-2009
Guess I was only thinking of myself I have a disk with SP1 already installed.
