Old 10-20-2013
PhIlLy ChEeSe's Avatar
Default Windows XP
guys,
I have a copy but it is scratched so bad it blue screens, suggestions? Beside mayonnaise? If I can get a XP copy i have a valid key, which is not used on other stuff i just need a good copy. The one for down load i can't open it?
HELP!
Old 10-20-2013
you burn the iso download image to disk and everything and it won't boot?
Old 10-21-2013
If it's for benching try Splaves Xp Ghost.
Old 10-21-2013
I couldn't open it, not good with converting I'm sure it was me......
Copy dat!
Old 10-21-2013
The thread for it.
http://www.overclockaholics.com/foru...ead.php?t=4742
Old 10-21-2013
what do i use to open it? imgburn OK?
Old 10-21-2013
OK, Im lost the file says its a GHO and imgburn says un supported file? What am I doing wrong?
this is what happens when i try to open the file with imgburn
Old 10-21-2013
Yeah, dun think imgbrn works with it. Splave uses norton ghost or sumtin like that. I have never used it before so unfamiliar of the workings.
Paging President Splave* Cleanup on Thread #2 Plz.
Old 10-21-2013
I can get Norton ghost the temp down load, I'll go back n read the thread. I can't make heads or tails of what there saying............UGH! BANGS HEAD ON DESK!
Old 10-22-2013
Use hiren utility disk. It has norton ghost on it. need that on a DVD then gho file on USB stick then boot the hiren disk go to backup/imaging tools. then choose partition to image, then the source file (gho) from image XD
