Old 09-02-2013
PhIlLy ChEeSe's Avatar
Default PCS P45 goodness
I got board gonna blow stuff up...............This board used to hold the world record(not mine)for memory speed back in the 775 days, lets see if we can find and beat that record. That and a few other records................
the test bed
subject TH45HP
Here's a link to the world record we shall be shooting at, one of a few.........Despite current trends-I am AN OVERCLOCK-A-Holic!
http://hwbot.org/submission/972015_l...eme_750.92_mhz
Here are the records of the Test Subject
http://hwbot.org/hardware/motherboard/tp45_hp/
I'll post more latter have to OS install, bring her up to speed, then we will add water to CPU n Chip sets and GPU.
Then rip it apart
Set up at present
BioStar TH45HP(SLI/CR-X)factory cooler fer now
Corsair DOM'S 1066
E6600(brand new been sitting around waiting)
AMD 4980(1 for now)
Intel 520 series SSD
OS:windows XP
Old 09-02-2013
Damm, that is one fugly board ..........
Rip it up Philly .............
Old 09-02-2013
I can't install raid drivers during XP without a floppy ugh!!!
Old 09-02-2013
lol, skittles!
Tear it up bro! Taste the Rainbow!
Old 09-03-2013
Go with a single drive for benching. You don't need to use RAID.
Old 09-03-2013
OK, I know I used to lose the raid cause of the over clock. Makes sense. Already spend four hours trying lols, fawking hate snags.
@Kal, my old board I got two of them now..
Old 09-03-2013
Finally installed the OS ugh!
Old 09-03-2013
Yea cause onboard RAID blows when it comes to overclocking. I did find though that when I used my RAID card and overclocked I never lost a os. But that was when I was into PCmark05. BEFORE they totally screwed the bench up with allowing all kinds of stupid tweaks. Now its a pussy bench test.
Old 09-04-2013
LOL!
You had an external rad card, correct, that's the one you was selling recently? Where is it?
I can change it to ACHI after install right? Do I have to use the Raid drivers then? I can't stand IDE, but it was the only way I could see the rad to install the OS....I want to turn on ACHI then install the drivers like I'm doing a fresh install but then abort after the drivers r in and it SEE'S the drive?
Old 09-04-2013
No need for RAID drivers if you're not doing RAID. Yes you should be able to turn over to ACHI after you install in IDE mode. I would also use the Intel Rapid Storage Utility.
No I didn't have the RAID card for sale. I had ACARDS for sale.
