Old 02-26-2013
Default Dumb question of the day
If I have a saved image (I do) for my gamer with a 150gb raptor in it, can I use the same image to setup the computer with an SSD in place of the raptor?
Old 02-26-2013
i wouldn't see why not, i've done it to my rig
Old 02-26-2013
Yes.
You will want to setup the boad the exact same way. (IE... AHCI/RAID/IDE) as you did wit hthe raptor.
Which should have been in RAID or AHCI anyway
Either works just fine.
Old 02-27-2013
cool
thanks!
but.. I think my raptor is setup in IDE, don't know why... it was a long long time ago that I first set it up ... oh well
okay, changed it to ACHI, jumped through some small hoops, now making a new image
Old 02-27-2013
Default MINOR PROBLEM
by restoring the image I formatted my 250GB SSD to be exactly the same size as my old 150GB raptor
Thank god I remembered some of what I had read for my A+ before I reformated the drive and started over Now everything is all better
Old 02-27-2013
LOL what software are you using to do your images? Doesn't it have "fit target" option?
But its easy to extend it in windows V/7, just go into disk management click extend and your done
Old 03-01-2013
I used the Win7 install disk to re-image and didn't pay a whole lot of attn to the on screen prompts :ohshit:
Used Disk Management to extend the partition but literally had the win7 install disk in and loaded and all set to reformat the drive when I remembered I could extend it phwew, a close one
Old 03-03-2013
LOL. I never tried win7 imager, I grabbed IFD when Kal got that discount for us way back when.
