Old 02-25-2013
Default 260 gtx Core unlock
Hey guys going to try this card on LN2 first. With Dice im able to get the card up to 1000mhz core with the modded precision on FTP but cant go any higher... Im pretty sure the core will go higher but cant get any of the software to go above 1000mhz core.
I've tried Afterburner, Rivatuner and Precision.
Even tried closing them and re-opening the tools with no luck. Thought theres a way to use Rivatuner but not finding it on google...
If anyone knows a guide to do this can you link it here?
Old 02-25-2013
Mr.Scott's Avatar
Mr.Scott Mr.Scott is offline
I'm assuming that you have the core and shader clocks un-linked. You have to move the shader up into the next strap.
Old 02-25-2013
No havent tried that, so how does work?
Just un-link them and move the shader then it will unlock the core and im guessing ill have to close the GPU app after i apply the new OC in order for the core to OC higher?
Old 02-25-2013
Mr.Scott's Avatar
This will explain it better than I can.
http://www.overclock.net/t/743811/in...r-straps/0_100
Old 02-25-2013
Hmm seems thats mostly for the shader mhz and the starps. And by the looks of their Riva pics it isnt unlocking the max mhz of the app for core or shader...
My problem is i've maxed out the core slider within the GPU apps to 1000mhz, the app simply wont slide any further allowing me to overclock past 1000mhz.
When i look at the top 260gtx 216 clocks they were able to reach 1100mhz on the core clock. So they have found a way to unlock the max mhz that the GPU apps allow.
Hope that make sense.
Old 02-25-2013
Mr.Scott's Avatar
Nvidia Inspector > unlock maximum clocks.
Old 02-25-2013
pretty much what this guy said.
clocking 260 is sooo much fun! and lots of boints too
Old 02-25-2013
Sweet thanks man!
