Old 02-19-2013
Default NZXT Phantom Enthusiast
Teaser pic's...
Old 02-19-2013
nice case
my kids would color all over that lol
Old 02-20-2013
Why do cases still come with 5.25" bays?
Not bad other wise...
NZXT still using all aluminum designs?
Old 02-20-2013
I think for fan controllers and bay resevors ...................
Sharp case though, the Giga OC board would be off the chain in that
Old 02-20-2013
I had the Zero, was an aluminum case and ran VERY cool. Case was like a giant heatsink.
Old 02-21-2013
Slight delay in assembly...I decided against a window side and I'm swapping out case fans for red led models. There will be a soft red glow visible from all screenage. Thinking of orienting the cooler so the 200mm top case fan draws the air upwards and out.
Old 02-26-2013
Installation of the Phanteks cooler proved to be a pain in the a$$...too many obstructions on this Classified mb. This configuration is the only way it will semi-fit.
These temps are just idle...having a bit of a problem with the rig atm. Just before dis-assembling the old pc to swap out parts I began to experience random bluescreens. Now, with fresh drives, memory and OS it will bluescreen at the drop of a hat at default settings. Hoping the mb is not going south.
Question - What should the NB temps be on this mb at default settings? It's showing around 105 degrees in bios within minutes of start-up.
EDIT: Problem solved...it is these damn Zotac 560 Ti video cards. Jerked them out and installed the trusty 5850 and she's running sweet now.
Old 02-26-2013
I don't recall seeing NB temps that high tho Rick, may need to inspect contact and TIM just to be safe.
Sexy handywork bro
Old 02-26-2013
Have to get to bed now, but a quick OC shows me the air cooler is holding it's own.
Old 02-27-2013
Nice bro, been awile since I have seen a Classy ................
