Overclockaholics Forums » Welcome to Overclockaholics » General Discussion » Can you Identify the missing parts
Old 02-18-2013
Question Can you Identify the missing parts
I sent this 560Ti to Gigabyte for RMA and they sent it back saying it was unfixable but I'm thinking if I can find out the identity of the missing resistors I can fix this bad boy. Was not a cheap card, so hoping someone knows what I need to buy and where I can buy it from
please please please Whatever they are, there are 4 of them.
Feel free to pass the pics around if need be If you know someone at Gigabyte even better
Old 02-18-2013
Why did they say it was unfixable because the solder pads are ripped off?
Old 02-18-2013
C724 is completely ripped out dude. that's what happened to one of my nice cards.
Old 02-18-2013
Mr.Scott's Avatar
Mr.Scott Mr.Scott is offline
They're SMD type caps. Without knowing what value they are I can't point you to a vendor. They're not expensive. Pack of 5 is only a couple bucks.
Old 02-18-2013
there is one way of doing it, i've never personally done it but taking one of them off and measure it and solder it back on then go out get the same rating ones and solder it back into the missing slots...
Old 02-18-2013
Bones's Avatar
Bones Bones is offline
Bones is just getting started
Nothing you can do but try it but like Mr. Scott said, there's no real way to know what was there without some technical info on the card.
You may be able to get this info somewhere, get the correct caps, solder them on and try it.
Old 02-19-2013
Well, I've written a very friendly letter to my good friends () at Gigabyte asking them to either
1 - sell me the parts I need
2 - provide me with the specifications of the missing parts
Hopefully they will do #1 but I'd be happy (an rather amazed) if they would just do #2.
TBA
Old 02-19-2013
I just got a response from Gigabyte
as follows;
Dear customer,
We cannot provide parts or specs for the components
Thank you
Rat Bastards
Such customer service, probably afraid of giving away trade secrets
Assholes
Old 02-19-2013
Thats suck MD, that's exactly the way i would have approached gigabyte too. Pretty bitch of them to send a reply like that.
Old 02-19-2013
mexican fartbox's Avatar
mexican fartbox mexican fartbox is offline
mexican fartbox is just getting started
Maybe you can find a broken one to pull the parts off of.
Just my $0.2.
EDIT
c724 is going to be hard to fix. if fixable at all.
Good luck.
/This is Bob Copy And Paste Him So He Can Take Over OCA
