Old 02-04-2013
Default Corsair 900D
Sure looks pretty to me Price not too bad either, considering
http://www.amazon.com/Corsair-Obsidi.../dp/B00B1R8JT0
I'll be damned if I can follow the plumbing though
Old 02-05-2013
That is a nice build,
Oh no, there goes Tokyo ..........
Old 02-05-2013
Oh no, there goes Tokyo AGAIN
it is a really nice case!
Old 02-05-2013
looks lie theres two loops 480 is for the gpus and the 360 on top is for mb and cpu
wish i had a rig like that
Old 02-05-2013
should have used Crystal link on the GPU's so you could see the red goo
The top is a 480 too ..........
The return for the MB must be behind the MB
Old 02-05-2013
Top rad down --> CPU --> Mosfet block ---> Res --Top GPU --- 2nd/3rd GPU --> Bottom rad ---> Pump -- 2nd res -->
I guess after that back to rad1
Although that loop is not functional since the res should be attached to the intake port of the pump not the output...
EDIT: Found a larger pic, there is two pumps and hte special pump top for dual pumps. Its still oriented incorrectly.
Old 02-05-2013
it's right .......
pump/res/sorce/rad/pump on both loops
Old 02-06-2013
The res is attached to output of pumps. It might function but it is not "right" how would you bleed the loop? As soon as you uncap the res the loop would stop n'est-ce pas?
Hmm actually it would drain the loop as it would be forcing water into the res, but without the pressure of an air tight seal it would not be forced out through the res's tubing...
Old 02-06-2013
Hmmm,,,,,,,,,,,,
Edit:
Sorry Rich, the res is passive
think about it and you will see what I mean
Picture a bucket of water with no lid, as long as the water level is above the intake and outtake it remains passive
I do understand what your though process is here, one could argue the loop would drain onto the res, and even overflow it, but with the lack of air behind it gravity is just an idea.
Example.
Take a straw, dip it into your soda, when you pull it out their is no soda in the straw, leaving density out of the equasion.
Now if you put your finger over the end of a straw and pull it out the gravitaional pressure measured at 14PSI and change is not present, hence you see the soda is still in the straw & you can get a nice cold drink with out picking up the glass ......
Not sure if this makes any sense at all though and I may just be babeling ............
Old 02-06-2013
I can fit a Feser 3x140 in the top of my 800D, but not quite a quad (close though). If i cut out the bottom drive bays I could fit a 240, but wtf good is that Too bad it costs so much :ohshit:
