On one hand, look at that temps for 1.4 volts on a qx6850 @ 4ghz with the GTZ waterblock + pa120.3 & pa160 2 pump 2 gpu + chipset loop.
73f 22c ambient outside. A/C running in office
On the other hand, picture setting 1.45v in the bios and getting 1.4 in windows then seeing a 1.35 drop off during the tail end of the run.
edit: forgot to spec it out........
790i ultra SLI mobo Evga
QX6850 GTZ waterblock
Koolance Chipset block
8800ultras x2 Koolance block
Ehiem 1-----Eheim2----upper P.A. 120.3-------CPU----Chipset------GPU1/GPU2-----Center P.A.160-----Return@ Ehiem1
