Old 11-14-2012
Default Repairing Feser Rads
I hacve a Feser quad and a Feser dual that have stress fractures around the fittings, and are thus.. leaking
May be garbage, but, am curious of what way would be best, if any, to seal the fractures? Thinking about some sort of epoxy, but ????
any ideas?
I mean, man, these things are irreplaceable
thinking 90 degree fittings werent't the best idea on these thin skinned rads
Old 11-14-2012
jb wled ?
Old 11-14-2012
you can try epoxy, sounds like it will work on paper ..........
brazing them would be a better solution though , but a PITA
you have to sand them back down to bare metal first to get the rods to stick
using a heavy silver content rod would help reduce heat but they are expensive bastards
Good luck bro
I have one for sale if you can't get it fixed up
Old 11-14-2012
I still have another quad I'm not using, just a bitch to throw them away
I have some heavy silver epoxy used to cold solder, actually used it to fix a video card, thinking that might work?
Old 11-14-2012
It's worth a shot bro .........
pics FTW
Old 11-14-2012
pics FTW
of what? the vid card? or the rad ?
Old 11-14-2012
Both ............
Old 11-14-2012
worked like a charm on the vid card, glued a cap back into place and it came back to life not sure about fixin the rad though ??
Old 11-15-2012
Old 11-15-2012
You want pics of a rad that's leaking? won't leak unless under pressure, so, nope
