Originally Posted by punx223
normally all you have to do is take keyboard off bro O.o
Yeah, or take off an access panel on the back. Not with this one. You can add 1 DIMM to slot 4 by removing the keyboard, you cannot access slot 1, which is also on the top of the mobo without removing the entire upper body structure. To do that, you have to remove the screen. Slots 2 and 3 are on the back of the mobo and require removal of touch pad and the entire back panel. Probably about 20 screws all in all
They told me they suggest sending the notebook in to their service center for memory upgrades - they can
Originally Posted by kikicoco1334
MD you crazy man! in a good way
Thanks Bro .. that's why I'm named MaadDaawg dude
