Originally Posted by MaadDaawg
I run my bench with no internet connection, so after I make a screeny, I also save the detail file on my thumb drive. Problem is, the details are in *.3dr format.
How do I open .3dr formatted files to extract the data when needed ?
So the computer your using to submit it with, should have the same 3D test on it(example 3D mark 03). You would opem 03 like your gonna run the test, but right click the mouse over 3D Mark03, it will show "options" hit submit saved score(have the file on the desk top) then find it through 03 hit submit boom done.
