Old 08-31-2011
der8auer der8auer is offline
der8auer is just getting started
Default [der8auer] Raptor GPU-Container
der8auer Raptor GPU-Pot:
Details:
  • Solid Copper LN2/DICE Container with Aluminium-top
  • Polished contact surface
  • High surface structure with 2x18mm and 4x10mm drilling
  • Universal mounting for all popular cards (58-86mm diagonal)
  • Black POM-Backplate for equal weight distribution
  • Hole for exact temperature measurement behind GPU contact area
  • Dimension Container: 80x40x150mm
  • Weight: 1850g
  • 2-Way SLI/CF capable
Manufacturing impressions:
Raptor GPU-Container:
Quick look on the structure:
Raptor Pot mounted:
More soon
Old 08-31-2011
Another piece of beautiful workmanship Roman
Why would it be limited to 2 way SLI instead of 3 or 4 way? Not that I can do 4 way but just curious
Old 08-31-2011
Thanks mate
Just because of the size of the pot. With 40mm the pot is too big for "normal" 3-Way SLI Boards.
If you add the insulation and backplate to the graphics card it will take at least 3 slots. Could be even 4. Will test it tomorrow and post pics of the mounted container.
Old 08-31-2011
Wow, they look MASSive like it'll hold a load from hell
Old 08-31-2011
He means 480's
Old 08-31-2011
He means 480's
I should have read the dimensions eh
Old 09-01-2011
Ye they should
I made a prototype about one year ago just with 3 of the big holes as structure. Tested with GTX275 @ 1,6V and it worked pretty well. Just changed the structure a bit for faster cooldown
Old 09-01-2011
Few more pics mounted on a GTX260. More soon
Old 09-01-2011
yup, definately a monster
