Old 08-05-2011
Default Board or IMC issue?
Have a MSI Z68A-GD65 G3 sitting here, and hooked it up to get some SPi on.
2600K
OCZ 700W PSU
2x2GB Kingston Grey 2133 9-11-9-27-2T RAM
XP SP2 code base for OS
Install window, install chipset drivers, and off I went.
1866 9-9-9-1T runs no problem
1911 9-9-9-1T runs no problem
2133 9-11-9-2T not convergent or sqr errors
Went to all auto settings. (BIOS reports 1.34 Vcore 1.32Vtt and 1.63 vdimm)
Was using XMP profiles...
Installed SP3, then upped vdimm to 1.7
It passed once.
Tried upping BCLK to 102.4 (50 MHz jump on mem speed) it errors out again
1.75 vdimm still errors.
So.. not having a lot of familiarity with MSI boards, and seeing the ridiculously high VTT, is there something else I am missing? RAM passes memtest 4.2 (although memtest screen reports RAM as 910 MHz instead of 1066)
Waza seems to make the error occur sooner rather than later also
Old 08-05-2011
Sounds alot like the issues I'm having but with different mobo ram. I can't even run my ram at factory speeds.
Old 08-05-2011
69_Goat's Avatar
69_Goat 69_Goat is offline
Be sure to use the blue dimm slots (Dimm1 & Dimm3) on the MSI mb.
It's backwards from what Asus does.
Old 08-07-2011
Yeah I was using the right slots.
I dont have another 2133 set to test... but
I dropped the ram in my main system and with a little finangling ran 32M just fine.
My 1600 OCZ reapers, I clocked up to 2133 and failed. Now this might be that hte ram cant handle it but...
It runs faster and tighter than the kingstons on other multipliers.
Even tried 2133 10-10-10 and that still failed immediately.
Blending now, 15 minutes no sweat.
Going to have to switch CPUs around and make sure its not ths 2600K
Old 08-13-2011
HybridChiller's Avatar
SB mobo's are sometimes picky on the ram, some will work nice, other will work like crap
Old 08-30-2011
Hazzan Hazzan is offline
Team OCX
Hazzan is just getting started
that not from your IMC or your board bro .....you can run 2133 easy with that board..try this setting..maybe help.
DDR_VREF_CA_A 1.09500 Volt
DDR_VREF_CA_B 1.09500 Volt
AOCC 2007 - AOCC 2008 - GOOC 2008 - MOA 2009 - MOA 2010
Old 08-30-2011
Thats awfully high ref voltage.
It was ONLY with superpi 32M BTW, both memtest and p95 blend passed hours of stability.
thanks for the tip though
