Old 07-16-2011
marcam923's Avatar
Default SFF HTPC build
Specs:
Gigabyte GA-H67MA-UD2H-B3
i7 2600
Gskill Ripjaw 1600MHZ
2TB WD Black 6gbs
Corsair HX 650
Corsair H60
Lite-ON BD
Silverstone SFF - modded
EVGA GTX560 TI
This is so outdated and needs an update!
Old 07-16-2011
Very nice. I would be interested in how you formed the mesh grill so well.
Old 07-16-2011
marcam923's Avatar
Funny story, I ordered an OEM I/O panel from the Coolermaster store, forget which case it was from, but it had 2 USB 2.0 ports, and 2 USB 3.0 ports, along with a removable aluminum motherboard tray, for a different project that will be in the works one day.
They sent me the entire top for the case the I/O panel was from, which had the 2 identical pieces of mesh, one of which I used for the top of this case.
Cut a hole, cut slots to match how the panel mounted, and it was plug and play.
Pretty nifty, and I had thoughts of mounting a fan up there for additional breathing for the case, however once I slid the BD drive in, it would have been next to impossible. SO I hooked everything up, and the air flow from the fans in the front of the case caused enough pressure to actually get good airflowing out the top.
Old 07-17-2011
Racy!
Old 07-19-2011
marcam923's Avatar
Old 07-19-2011
That looks sick Marc!!
Old 07-19-2011
marcam923's Avatar
Thanks buddy!
