Overclockaholics Forums » Cooling Performance Section » Water Cooling » Questions about pumps, and tubing
Old 07-16-2011
marcam923's Avatar
Default Questions about pumps, and tubing
So I am going to start slowly ordering water stuff for my next setup.
First question, is the variable speed MCP655 worth it over the standard?
Tubing I want to go with Feser, UV reactive, anyone have pictures of difference in glow between the Black and Blue tubing? Nipster?
EK Acetal block vs. Heatkiller?
This is so outdated and needs an update!
Old 07-16-2011
1 - yes IMO. The non adjustable is set at #4 so you get a stronger pump with the adjustable at #5
2 - Feser tubing, IME, sucks It's too stiff and kinks easier than Tygon 3603, use UV reactive coolant to get your UV effect. I tried Feser once, never again.
3 - Look at the Aqua Computer Kryos line
http://www.sidewindercomputers.com/aquacomputer.html
There is one for each price point and each one will fit on any intel socket without any changes to the mounts. Heatkiller and EK mounting brakets are socket dependant so you have to buy multiple mounts and change them if you move the block to a new board. I use the HF on my gaming rig.
Old 07-16-2011
marcam923's Avatar
Good stuff!
Variable speed it is.
http://www.sidewindercomputers.com/aqcocukrrfso.html - CPU block
Tygon clear tubing. Which fluid would you recommend? The only reason I was going to go with UV tubing, is to use distilled water.
I noticed that with the heatkiller blocks and mounting...
Old 07-16-2011
I use Feser UV reactive dye that comes in small, maybe 3 or 4 oz bottles then mix it with distilled water
edit: I stand corrected, the EK blocks will fit multiple sockets. Problem is they're fugly : Also, the Kryos have a great pin matrix for cooling
Old 07-16-2011
marcam923's Avatar
OOh another good question, I will only be cooling my 2600K, 120.2 rad good enough? is a 120.3 overkill?
What rad would you recommend?
Old 07-16-2011
marcam923's Avatar
So I am thinking:
http://www.sidewindercomputers.com/ty1id3odlatu.html
http://www.sidewindercomputers.com/fevifvacuvdy.html
http://www.sidewindercomputers.com/peptpcobi1.html
with a variable mcp-655 pump, just need to lock down the RAD, will go with this res:
http://www.frozencpu.com/products/95...l=g30c97#blank
Old 07-16-2011
I would roll with the 2x 120 for Sandy, My h70 does a decent job and provide stability at 4.5 24/7 for my gamer in a warm inviroment.
use the 3x120 for the vid card or cards depending on what your doing.
My experience with the 655 and all the rinky dink water cooling site pumps is that they all blow .....
Ehiem FTW .... more work involved though
http://www.buy.com/prod/eheim-univer...211941442.html
It will pwn ............ just make sure you have your clamps tight ............
Old 07-16-2011
I wasn't ever happy with the feser coolants glow. I ended up going with the blue tubing and blue coolant for this. I only went with the blue coolant due to the reservoir being clear.
Let me dig around for some older pics of when I had clear tubing and blue coolant.
Old 07-16-2011
Well I guess when I had clear tubing I had the black coolant that glowed blue. I loved the black but the glow blew goat balls.
Old 07-16-2011
Or you can roll with this...http://www.overclockaholics.com/foru...ead.php?t=4691
Freestanding feet available if you desire...http://www.performance-pcs.com/catal...ducts_id=29066
