Overclockaholics Forums » Welcome to Overclockaholics » Hardware/Software News » Asus Dual GTX 285 a.k.a. gtx295 w/voltage control
Old 05-28-2009
Default Asus Dual GTX 285 a.k.a. gtx295 w/voltage control
ASUS Designs Own Monster Dual-GTX 285 4 GB Graphics Card
ASUS has just designed a new monster graphics card that breaks the mold for reference design GeForce GTX 295, called the ASUS MARS 295 Limited Edition. The card, although retains the name "GeForce GTX 295", same device ID, and is compatible with existing NVIDIA drivers, has two huge innovations put in by ASUS, which go far beyond being yet another overclocked GeForce GTX 295: the company used two G200-350-B3 graphics processors, the same ones that make the GeForce GTX 285. The GPUs have all the 240 shader processors enabled, and also have the complete 512-bit GDDR3 memory interface enabled. This dual-PCB monstrosity holds 32 memory chips, and 4 GB of total memory (each GPU accesses 2 GB of it). Apart from these, each GPU system uses the same exact clock speeds as the GeForce GTX 285: 648/1476/2400 MHz (core/shader/memory).
Each PCB holds 16 memory chips, a 6-phase digital PWM power circuit, drawing auxiliary power from an 8-pin PCI-E power connector, the GeForce GTX 285-class GPU, and its companion NVIO2 processor. The PCB holding the PCI-Express bus interface, also holds the bridge chip. ASUS broke away with using the nForce 200 chip, and instead is using a yet to be disclosed third-party bridge chip. Currently, PLX and IDT are two likely sources for such a chip. The memory consists of high-density 0.77 ns memory chips made by Hynix.
The electrical-management on each PCB is care of a Volterra VRM controller, which supports the I2C interface, which means that the card supports software voltage control, perhaps a big plus for ASUS' Voltage Tweak feature that is gaining in popularity. Fused power circuit provides Over Current Protection while also facilitating extreme overclocking.
The cooler internally has the same basic construction as the reference cooler, it uses a single leaf-blower. The card spans across two expansion slots and is slightly higher than the reference design card. ASUS also used slightly longer internal bridges that make more room for third-party coolers, and the likes. Our source from ASUS EMEA conducted a quick 3DMark Vantage test proving the card's seamless compatibility with existing drivers, while also providing a significant boost in performance over existing GTX 295 cards. Being Quad-SLI capable, this card finally makes GeForce GTX 285 (effective) quad-SLI possible, and makes for the most powerful desktop multi-GPU setup ever conceived. ASUS designed this card despite pressure from NVIDIA enforcing its rigid policy of restricting its partners from custom-designing GeForce GTX 295. If everything goes smooth throughout the development process, the card might make it for a gala launch at Computex.
Looks pretty darn sweet! Volterra Chip included!
Old 05-28-2009
THAT ^^ is what GTX295 should have been from the start. Shame shame shame on nvidia for that! I can't believe I'm saying it but that sounds like an awesome card.
Old 05-28-2009
We'll have to see how well it overclocks. From a gaming standpoint it looks killer right out of the box. The volterra chip is promising. The 3 pwms per gpu is a little concerning as the standard GTX285 has six per card but the six may just have been overkill. It's not like we'd be fortunate enough to pick up one of the 1000 that will be released, 900 of them are likely reserved for Vince and company.
Old 05-28-2009
Re-read that bud. It has six phase on each PCB That's 12 phase digital pwm Plus those volterra phases are supposed to be wicked sick for handling a huge load. That's what is on the classie and DFI. We all know those boards rule on the big overclocks.
Old 05-28-2009
SkimmerOwned!
