Originally Posted by Witchdoctor
GIMP FTW
Nice build chuch .........
Now clean that shit up, you are giving every self respecting enthusiast a bad name ...
Dude GIMP, Paint.net, Photochop..... I just don't understand those darn programs. I mean they have so many tools and whatnot. I guess if I had time to sit and read guides and the help files I could figure it out.
I think it will look a lot better once I change a few things. Different fans will make a large difference I think. Plus when I get some different memory I can take that corsair fan out. Right now I have to use it since the modules get so hot on my kit. I'm thinking Scythe Gentle Typhoons for the rear 120mm and Venomous X. As for the 140's I don't know. The selection sucks for 140mm. I'll probably just splurge on some noiseblockers. I also need to get some tie down anchors for the mobo tray backside and matching SATA cables. Then I'll tidy the other cables up.
My only gripe with this case is the mobo cable management holes. With the position of my SATA ports I can't use the bottom hole for the VGA cables. I guess they'll have to stay like they are.
