Overclocking Air & Water...
Old 05-13-2011
Spank's Avatar
Spank Spank is offline
Junior Addict
Spank is just getting started
Default Pcmark 7
I will make the start with pcmark 7 benchmark
Also hwbot http://hwbot.org/community/submissio...975_4911_marks
Intel Core i7 975 Extreme Edition 4.3GHz 1.375vcore|Asus Rampage 2 Extreme|Corsair Vengeance LP 12GB DDR3-1600|Asus GTX570|Creative X-Fi Titanium-Fatal1ty|Intel Postville 80GB SSD,300 GB WD Velociraptor,2X640GB WD|Silverstone Strider 1500W|Samsung Syncmaster P2370|Coolermaster Cosmos 1000|Razer Lachesis Precision 3G Laser|SteelSeries 5H v2|
Old 05-13-2011
HybridChiller's Avatar
What hdd or ssd are you using ?
Old 05-13-2011
Spank's Avatar
Junior Addict
Old 05-14-2011
sumonpathak's Avatar
sumonpathak sumonpathak is offline
sumonpathak is just getting started
my horrible run
http://www.hwbot.org/community/submission/2168365_
no SSD's......must....resist......upgrade itch....
Old 05-14-2011
BenchZowner's Avatar
A good SSD is a 2-way upgrade with 100% efficiency ( superboost for 24/7 system, plus you can use it for your benching with PC Mark )
Old 05-14-2011
Ran it on my ROG notebook but HWBOT never heard of my proc or vid card
Not bad for completely stock, I'll have to load some more software and see how far i can bring it up
Old 05-14-2011
The BIO on the ROG lappy gives you VERY LITTLE ability to overclock About all I could do is turn off virtualization. Eleet won't work, precesion won't work... bummer but got it up a couple more boints.
Old 05-14-2011
What test are we supposed to run? All of them or just the pcmark suite?
Old 05-14-2011
just the suite
Old 05-15-2011
3408 on my HTPC.
http://3dmark.com/pcm7/31919
