Overclockaholics Forums » Hardware Section » Motherboards » Intel » Msi P67A GD-65 or BIOSTAR TP67B+ P67
Old 04-14-2011
Default Msi P67A GD-65 or BIOSTAR TP67B+ P67
First off I'd like to say sorry for being awhile from OCA forums and bros for a minute. I started working for GE in the data center mostly working with server install/de-installs, trouble shooting, and cabling. Which for me is a dream job but at the same time can be a nightmare trying to cram tons of information in my head .
Anyway looking to take the plunge into the 1155 socket, like the title says I'm deiciding between the Msi P67A GD-65 or BIOSTAR TP67B+ P67 . I want to cut costs on the board since 2011 socket and X67 are just around the corner. I'll be getting a 2600k cpu and using WCing and if DICE is needed staying around -20c (from what I've seen lower temps are worse).
If anyone has input I'd love to hear from you guys
Msi P67A GD-65:
Pros as I see it.
Easy to prep for subzero cooling
Ability to enter up coming MSI events
military class components
Nice results on Hwbot
Cons as I see it.
Priced about $60 higher than Biostar
P55 memory was hard to OC, maybe fixed with P67??
BIOSTAR TP67B+ P67:
Pros as I see it.
Cheaper
Cons as I see it.
My DICE pot may hit the caps around the socket
Cheaper Quality???
Easy overclock???
Customer support???
Forgot to mention I'm going to see if I can pull the trigger on this tomorrow if not then sometime next week................
Stupid HR payroll procedures...........
Old 04-14-2011
good to see you around bro, I don't know much about either of those boards
But rumor has it you chip either has it or it don't ....
Nip grabbed 5.6 with his MATX asus ....
Rick I think had a Bio Star, may try PM;ing him and I beleive Splig had an MSI '
he may even have some binned CPU's ..............
Old 04-14-2011
Thanks WD helpful as always bro. I'll dig around more and see what I can come up with. Hoping this platform will rack up some boints for 2D & 3D benchs, seems like 01 is breezy with Sandy on your side..
Old 04-14-2011
Ive had 2 p67gd65s and I have killed them both lol! they were b2 but I cant suggest them atm
Old 04-14-2011
SB = Easy Bake Oven
throw a card in and watch the boints heat up
Brought to you by Hasbro International Inc. LLC.
Old 04-14-2011
i been using ud5 b3 its mostly cpu you have to bin or buy ones that oc which i did after 2 2600k
but i lik asus but didnt have themoney for a m4e so got the ud5 been a sold board untill i tryed to flash the back up bios...
but never going to try that again lol
even seen ud4 oc good think only reason i got the 5 was it has the power button
