Overclockaholics Forums » Hardware Section » Motherboards » Intel » Gigabyte P67 UD7 "Socket Burn"?
Old 04-09-2011
Exclamation Gigabyte P67 UD7 "Socket Burn"?
Finally decided to give this chip a rest and move onto the next chip. This is what I found on the bottom of the chip. The corresponding area of the socket also showed slight mirror signs of burn. Does anyone know what circuit duties this area of cpu pads are responsible for?
The chip still does x54 fine and stable but needs cold to do x55.
Max Voltages used:
vcore 1.67
vdimm 1.72
vtt 1.22
level 2 LLC
Max clocks 5.5ghz run
F2 bios
Hi-Res 1
Hi-Res 2
Hi-Res 3
Hi-Res 4
Hi-Res 5
Hi-Res 6
Hi-Res 7
Old 04-10-2011
Pad layout, looks like all the ground pads blew chunks.
Old 04-10-2011
Will have to check, but it seems even mine has similar burn marks on the chip.........
Old 04-10-2011
Dude with LLC2 you were giving it 1.7x vcore at load.
Old 04-10-2011
Damm that sucks ....
Is this common to the UD7 or the chips themselves,
I have been around 1.64 to 1.665 with mine.
Old 04-10-2011
The only other "incident" I know of with any board is a pre-release UD7 and ES 2600k that miahallen had.
Old 04-10-2011
Chip 2 does x56
Heres what chip two looks like.
llc1
1.66vCore
1.20vtt
1.72vDimm
Still on bios F2
Hi-res
Old 04-10-2011
looks like rma time.... can newegg replace them ?
but ill keep the x56 lol
Old 04-10-2011
I don't think its common but peeps should peep the underside to be sure.
Its still a good x55 chip tho so I'll keep it for an oca duder after I test it on legitmate sub-zero cooling.
Lemme know if you guys find any sorta abnormalities on the underside of your chips.
Old 04-10-2011
freeagent's Avatar
freeagent freeagent is offline
freeagent is just getting started
Yikes, that really sucks :(
Sorry to see, but I do have to admit it looks pretty neat
3770K @ 4400 1.215v/True Spirit 140 Power/TY-143|Asus P8Z77-V|12GB G.Skill TridentX+RipJawsX @ 900 9-9-9-24 1T 1.6v|EVGA GTX 980 Classified 3988 @ 1497/2001|CM Silent Pro M2 850|Fractal Design Meshify C
X5690 @ Stock+Turbo/Le Grand Macho RT/TY-147B|Asus Rampage III Formula|12GB STT Chrome+OCZ Reaper @ 667 6-8-6-24 1T 1.6v|EVGA GTX 970 FTW ACX 2.0 @ 1404/1753|TT SPM850|Fractal Design Define R4
