Old 03-30-2011
Default ROG connect and 990x
Anybody having trouble with it?
Finally figuring out how to coax clocks out of a 580 CUII in Vantage, but keep crashing on CPU tests after beautiful 3D runs at 1300+.
Turns out ROG connect keeps borking out and suddenly dropping voltage back to my bootup voltage. (Right now I'm praying that my current "CPU init" hangup is just condensation...)
Using the most recent (public) R3E BIOS.
I'll reinstall the software and try again tomorrow.
Old 03-31-2011
Deux's Avatar
Deux Deux is offline
Deux is on a distinguished road
I didn't have any issues with ROG connect and 990X, was on 0010 and 0096 though, not sure if it makes a difference.
Sounds like you've got the card figured out, 1300+ is nice
Old 03-31-2011
sorry patch, I use OC station
Old 03-31-2011
Dried out and reinstalled ROG connect on lappy. Workin fine now.
