Old 03-06-2011
Default Gamer
Had some time today and thought I would get some tools out and do some prep work for an inpending build.
Wanted to go small form factor but ultimantly decided to go full ATX ....
This was the smallest AXT case I could find that I liked.
Specs:
Case = Lian Li AO5NB Mini ATX
Power = Antec TPQ1000
CPU = Intel 2600K
CPU Cooler = Corsair H70 closed loop
Motherboard = Still not decided with the chip set debacel (Leaning towards UD7 ATM)
Memory = G.Skill Ripjaws 2133 7-10-7-24
Video = 2x eVGA 580 vinilla's
Sound = Creative Xfi Pro
Win 7 64 drive = 60GB OCZ Vertex 2
Win XP drive = 74Gb raptor
Game drive = 80 GBIntel SSD
Boneyard drive = WD Black 640
Had some fun playing with power tools today .....
Through some handles and a couple intake fans in the top
More to come
Here are some more pics
http://www.overclockaholics.com/foru...1&postcount=44
Old 03-06-2011
Good start dude. Now hopefully the mobo's come in stock so you can finish.
Old 03-06-2011
Cyberjackal's Avatar
Cyberjackal Cyberjackal is offline
Cyberjackal is just getting started
Not bad at all bud. Looks sweet!
Good luck on your project
Cyberjackal
Next Build:
~ Intel Core i7-4790k hex-core (LGA 2011-3)
~ Asus Rampage V Extreme mobo (X99 chipset)
~ 32Gb G.Skill Ripjaws 4 DDR4-2400
~ 2x EVGA GeForce GTX 980's in SLI
Win7 Ult x64 - Arch Linux
Other Rigs:
~ Intel Core2 Quad Q9450 / Asus P5N-D mobo / 8Gb Corsair Dom XMS2 DDR2-800 / R7870 Hawk (GHz edition)
~ AMD Phenom II X6 1090T BE / GeForce GTX 570
~ AMD Phenom II X4 925 / GeForce GTX 550Ti
~ AMD Athlon II X2 250 / GeForce 9800GTX BE
~ AMD Athlon 64FX-55 / Radeon HD4650
Old 03-07-2011
Nice start Bri. Are those the handles you wanted me to look into for you?
Old 03-07-2011
Dr. Witch will adding those two fans give that case enough ventilation for those massive cards?
Old 03-07-2011
Interesting.
Those fans just placers or you going with top down intake?
Old 03-07-2011
Duke, yea they are, found them at Lowes ...........
Chuch, They will roll 220 CFM into the the case as intake air, Roughly enough air to heat or cool 14' x 20' room with two windows ........
Neuro, Yes down firing intake This case it is the only logical way to cool it
I used to have a down firing system that was really efective back in the day, so thought I would roll with it again ....
Old 03-07-2011
Love my Lian Li AO5NB. Great Case!
Old 03-07-2011
You have a case?
Old 03-07-2011
You have a case?
Yeah, for the main rig. http://www.overclockaholics.com/foru...38&postcount=1
