Under the influence of being Over the Edge!
Old 03-04-2011
HybridChiller's Avatar
Send a message via MSN to HybridChiller
Default Reeven Cpu pot
When i whent to Cebit, in a little corner in Hall 16 or 17,
i found a Brand that i never heard before : Reeven.
http://www.reeven.com/comming-soon/
And they showed there a new cpu pot, i made some pics of it,
some specs :
the manager said it would cost around 150euro 200dollar
Weight: 900gram/ 1.88lb (Heatsink only)
Dimensions : 160 x 70 x 70 mm
Material : Alu cup, Nickel plated copper base.
socket support : intel 775,1155,1156,1366 amd AM3,AM2+,AM2,940,939,754
made in collaborating with Overclock works and Scythe (overclock works i don't even know or heared from them lol )
this was a nice thing to post here as info for Xtreme overclockers under us.
hope you enjoy the pics
Old 03-05-2011
crio's Avatar
crio crio is offline
Nice one but 900gramms is quite light.....:(
We shall see
Crio OC
Old 03-05-2011
indeed, when i had it in my hand, it was nothing, so light OMG
Think when the load comes, the temp raises high.
Old 03-05-2011
GeorgeStorm's Avatar
Send a message via MSN to GeorgeStorm Send a message via Skype™ to GeorgeStorm
Will be interesting to see how it performs
Old 03-05-2011
I like the hieght if it, prolly make a decent dice solution
Scythe getting in the game
Old 03-05-2011
i think it's a good pot for dice, but not so for LN².
not enough mass, and the height of the pot is good for dice.
A dice pot with a little more mass, sounds good.
for ln² not enough mass lol
i asked for a sample, so let's see and wait untill i get an answer.
Old 03-05-2011
OC4 Japan E-Quake Contest
Send a message via AIM to Kal-EL Send a message via MSN to Kal-EL Send a message via Skype™ to Kal-EL
Still curious on how it'll perform either way
Want to be an "Overclockaholic"?
U.S. Hwbot Rankings-
"Overclocking........the fabric of my life"
Don't know how to effectively bench 3Dmark2001SE? Vivi's guide be your path
Having trouble with using copywaza effectively in Super PI 32m? Check out the waza tweaks on the Overclockaholics Channel
Old 03-07-2011
Send a message via ICQ to kikicoco1334 Send a message via AIM to kikicoco1334 Send a message via MSN to kikicoco1334 Send a message via Yahoo to kikicoco1334 Send a message via Skype™ to kikicoco1334
well... i am still working on my pot
Old 03-07-2011
can we get sneakpeak of you're pot ?
Old 03-07-2011
It's still in auto cad there is no real product yet :'( but I'll make sure oca members are gonna be the first ones seeing it and using it
school is kids kicking my ass right now
Copyright ©2009, Overclockaholics
