Overclockaholics Forums » Hardware Section » CPUs » Intel » help overclocking please..........
Old 02-04-2011
ny_driver's Avatar
Default help overclocking please..........
I have never had an Intel before, and it seems like there is a lot more to it than with AMD.
Anyways, right now I'm just trying to see if I can get a good cpuz run.
I set the vcore to 1.35v for a test run and left everything else on auto because I don't really know what else to do. I disable HT, overspeed protection, and c-state, and I set it to 1 core.
It crashed at like 3.3GHz, which just made me feel confused and clueless. I guess I need some coaching here.
Thanks!!
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 02-04-2011
Mr.Scott's Avatar
Mr.Scott Mr.Scott is offline
You're just confusing yourself. Everything OC's the same way......just the nomenclature is different.
Old 02-04-2011
ny_driver's Avatar
Maybe I am, and it probably is mostly a terminology issue, but I still need help.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 02-04-2011
dont set it to 1 core
turn off all the crap and ht, disable speed step and all c states.
uncore multi must be x2 ram multi or higher, up to 1.55vtt seems to be okay, up to 1.6vcore is okay.
Old 02-04-2011
bclk starts @ 133
go to 136 - 139 - 142 etc.. - ....using just bios...
Old 02-04-2011
ny_driver's Avatar
OK thanks Splave. I just gotta get SetFSB to OC with I guess. I really wish there was a handy program for remotely overclocking/monitoring like on ASUS.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 02-04-2011
BIOS does a fine job
just got to play with it a bit
Old 02-04-2011
gigabyte ...doesn't have one...
Old 02-04-2011
ny_driver's Avatar
I honestly thought I was done having to constantly go into the BIOS to make adjustments unless it crashes.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 02-04-2011
Wait, wut hardware we talking about specifically?
