Old 02-02-2011
Default SB Survey
I would like any and all to post here if you have experienced hdd/ssd failures or corruption from the Intel chipset saga.
I will begin with mine. I have lost 8 installs total before swapping over to the 6 Gb/s ports...none thereafter so far. Feel free to link to other forums posts as well about the subject. While we are here also include your experiences trying to install XP with this platform.
Old 02-02-2011
I never had failures or corruption
killed a hd cuz the ps was bad
Old 02-02-2011
You don't have a SB bonehead...
Old 02-02-2011
i know but your always messing up your OS/HD's must be the user
Old 02-02-2011
OMG!
but yeah a good friend of my just got 6 of his 1.5T gone out on his ass today
time for rma baby!
Old 02-02-2011
OMG!
time for rma baby!
No RMA available I bet, the B3 stepping PCH is not going to be available very soon. April is expected delivery date. I think.
I have not killed anything, but I am not running SSDs on it either because I could not get Gparted to run on a USB stick on SB. I did eventually added my last functional optical drive to the PC later and gparted ran fine from that... memtest and such still crash though.
I got a little data corruption when mem tweaking , but that is expected. Returned to low OC, fixed it and back about my business easy peasy.
So... no.
XP (well FLP) installed fine from optical in IDE mode. Did the driver install/reg tweak rebooted into RAID mode and away I went.
Old 02-02-2011
Hdd/ssd, all the same...I'm talking about high clocks people.
Old 02-02-2011
never had one go bad...
tiny7
win7x64
win7x86
xplite
dom must be right...
Old 02-02-2011
Hmm corsair drives eh? Just had my second die on me. (was not used on the SB though)
No high clocks here. Only 5.2 ish. am running 104 BCLK though.. approximately all the time.
Old 02-02-2011
Zero, Zip, Nada SSD/HHD issues here, and I've been benching like a mofo since I got my SB setup.
TOP 5 MOST ACTIVE MEMBERS IN THE PAST MONTH.
OC Maximus: 55 submissions worth 492.2 points.
DOM.: 13 submissions worth 265.4 points.
Splave: 5 submissions worth 248.9 points.
steponz: 13 submissions worth 198.4 points.
rickss69: 35 submissions worth 130.8 points.
But then again I had my SSD and Backup HDD in Sata port 0/1 since day 1.
WTF is up with SB + ASUS?
OR is there something else causing all these dead ssd/hdd issue in your hands?
