XP Ol' Reliable...
Old 01-20-2011
Question Windows XP
real quick...
i was looking around for 2d bench, and all the tweaking for it, and how i saw there most people are using the tiny xp or the traditional chinese windows xp is that REALLY better than all other xps?
i been using simplified chinese windows all along and seems like worked the same msot the time when i used traditional chinese...
and i know when i am doing super pi it's based on both ram and cpu, and the lower the subtimming the faster it gets in the end... dose rampage extreme or DDR3 overall help with the sp scores?
wprime is cpu based right? as many cores you have the higher the core speed is the higher score you gonna get out of it...
Old 01-20-2011
superpi 1m.....x48 and p45 are very close....
superpi 32m ....ddr3 seems to help alot..the sheer bandwidth just leaves the ddr2 behind
wprime is cpu and some tweaks..like display resolution
Old 01-20-2011
damn it! so aka... get my stupid ass a rampage extreme or a P5E3 Premium/WiFi-AP?
cuz my new e8400 will want to be on a x45 baord
i just went on ebay and noone is selling P5E3 Premium/WiFi-AP right now
and there is more people that's selling rampage iii extreme then rampage ii or rampage extreme!
there is one i am watching right now hopping to get and maybe fix
http://cgi.ebay.com/ASUSTeK-COMPUTER...item230d8ff0f6
Old 01-20-2011
what about the diff between the xps? are they really different or what?
i mean tiny xp is for sure different but what about all the diff between the xps?
Old 01-20-2011
they're almost all identical xp's but make sure sp3 is used
Old 01-21-2011
will do bro!
i monna try get a clean xp sp3
Old 04-03-2011
Spank's Avatar
Spank Spank is offline
Junior Addict
Spank is just getting started
I will install windows xp to a parition right away so i can start benching hoping for better scores than win 7
Intel Core i7 975 Extreme Edition 4.3GHz 1.375vcore|Asus Rampage 2 Extreme|Corsair Vengeance LP 12GB DDR3-1600|Asus GTX570|Creative X-Fi Titanium-Fatal1ty|Intel Postville 80GB SSD,300 GB WD Velociraptor,2X640GB WD|Silverstone Strider 1500W|Samsung Syncmaster P2370|Coolermaster Cosmos 1000|Razer Lachesis Precision 3G Laser|SteelSeries 5H v2|
Old 04-03-2011
HybridChiller's Avatar
wprime : display reso helped me a lot
Old 04-03-2011
Spank's Avatar
Junior Addict
Is there any specific xp version to install to have the best results ? Also what about the 4gb limitation of the x86 xp has ? i have 6gb
Old 04-03-2011
Less memory used the better off you are.
