Old 12-22-2010
ny_driver's Avatar
Default WPrime32
How come my score is ~53 seconds and everyone elses score with same or similar hardware is ~30 seconds. 4200+ Manchester....btw
Do I need to set WPrime to use both cores or something? My Opty 152 single core score is right up near the top so I'm confused...maybe there is something wrong with the cpu? ( my brain)
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 12-22-2010
yes use both cores...
its a multithreaded benchmark
Old 12-22-2010
ny_driver's Avatar
Since when do I need to tell it to use both cores? I thought it did that unless you told it to only use 1.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 12-22-2010
No you have to tell it how many threads everytime you open it. It doesn't save the settings.
Old 12-22-2010
ny_driver's Avatar
ahhhhhhhhhhhh....I'll have to figure that out. Thanks.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 12-22-2010
Advanced Settings then set threads
