Old 12-21-2010
Default Core Temp
Anybody still use this app? http://www.alcpu.com/CoreTemp/
I remember back in the day when we used Core Temp religiously on the older platforms.
Old 12-21-2010
Mr.Scott's Avatar
Mr.Scott Mr.Scott is offline
I still use it.
Old 12-21-2010
Does it not show voltage???
Old 12-21-2010
its called coretemp for a reason
lol just messing with you... but i didnt use it, used speedfan back then
and it doesnt show volts
Old 12-21-2010
Mr.Scott's Avatar
Maybe that CPU is not supported.
Old 12-21-2010
i think his talking about volts like in cpuz
and your comps named master lmao
Old 12-21-2010
Mr.Scott's Avatar
Ahh...ok. I misunderstood.
Yes my daily driver is named Master. I also have the Bencher family. Bencher NF2, Bencher NF4, Bencher 370, Bencher Slot1, Etc. Get the idea?
Old 12-21-2010
I was thinking 4sure ther'd be a "Slave" machine??????
But yah, usually the VID should show me thinks with core temp. Also, I know with some processors, you need to play with the tj max offsets to obtain true temps.
Old 12-21-2010
Mr.Scott's Avatar
The "slave" would be me.
Old 12-22-2010
I also use coretemp. Mainly because RT doe not work right on AMD IME
