Old 11-18-2010
Default Heaven
Best score for me with 1 air breathing 480 and a wc 975
Old 11-18-2010
I have the same problem as Duke used to have, I take a screen shot and then when I paste it to paint it's nothing but BLACK! Good thing Heaven allows you to save the html page shot so you can make a screeny after the fact
Paint only worked once for me, the rest of the time it was black :(
Old 11-18-2010
This was the solution the OCGMJ had and it worked for me with Aquamark.
Duke try the following:
right click on the aquamark icon-->select properties-->select compatibly tab-->check the last four boxes, 3 disables and run in admin mod.
Old 11-18-2010
Kewl,
Thanks Bro
